Question about Daisy Powerline 901 - 0.177 Caliber Powerline 901
Losing power while pumping air rifle
Never over pumped can hear and feel lose of air pressure
    Problem Solver:
  • 8 Answers
Oil the air cylinder , thats most likely your problem
Posted on Oct 25, 2013
2 Suggested Answers
  • 214 Answers
SOURCE: losing air pressure
Try oiling the cup with air impact wrench non-fluid oil or 3 in oil
Posted on Oct 21, 2013
Why does the pump lose pressure? there are no visible leaks, of water or air
for the pump to lose pressure there has to be a leak somewhere please check and make sure you have a one way valve on the bottom of your jet pump that will not allow the water to run back into the well
Nov 29, 2014 | Utilitech 1/2-HP 9-GPM Shallow Well Jet...
My suburban when you take off some times it feels like it has no power and also it sometimes feel like it lose powers going down the road
a tuneup with new distributer cap--plugs--wires works----also new air cleaner--fuel pump may be worn-get a pressure test----transmission cud be worn also along with torque converter-hav a pressure test done also--inspect fluid-if dirty and low-changeit--dont flushit
Oct 12, 2014 | 1997 Chevrolet Suburban
Losing air pressure
Oct 21, 2013 | Daisy Powerline 901 - 0.177 Caliber...
My grizzly 840 loses air when i pump it
You need to pull it down/apart & install new "o" ring
Aug 20, 2012 | Daisy 840B Grizzly Youth BB Air Rifle Kit
Losing pressure after about 15 mins pool pump stars really well but then seems to lose pressureleaf catcher before pemp seems to get air in it is this pump or pipes
If the inlet strainer gets air in it, the pump will lose prime. Fill the inlet strainer basket with water, make sure the cover is on air tight. Start the pump and watch the inlet strainer, the amount of air trapped should not increase, if it does, you have a leak somewhere on the piping between the pool and the pump.
Nov 19, 2010 | Plumbing
Switch fails to turn on pump properly
sounds like its a lose wiring in the switch, or your spring bolt is jaming inside the cover of the power surply
Jul 27, 2010 | Square D 9013FHG14J52M1X Air Compressor...
While traveling engine will hesitate, ****, lose power
Check the least expensive first. Check the fuel filters first and replace them if they are plugged. Most likely it is the fuel pump. A shop can check the fuel pump pressure at the fuel rail on the engine under the hood. If the filter or filters were checked first then a low pressure would indicate that the pump is weak and needs replaced.
Jan 21, 2010 | 1996 Jeep Cherokee Sport
When my pump turn on it does not want to work you hear it running but that is it, it sound like it needs to be primed or something to kick in gear
you will need to fill the pump hair/lint pot full with water before you try to start it up. If it keeps losing prime, you'll need to investigate why it's happening. A possible air leak on the suction line, a cracked lid o-ring, an extremely dirty filter, or an air leak in the multiport valve on the filter. When the pump picks up prime, check for air bubbles in the pump pot, excessive air getting into the pump indicates a suction side leak. Any other leaks on the pressure side will lead you to where it may be letting air into the system and causing the pump to lose prime while the system is off.
Nov 09, 2009 | Hayward SAND FILTER, PRO SERIES
Daisy Powerline 901 - 0.177 Caliber Powerline 901 Logo
177 people viewed this question
Top Daisy Optics Experts
BJ Russell
Andrew Taylor
Andrew Taylor
Are you a Daisy Optic Expert? Answer questions, earn points and help others
