Question about Saws
Cant see m to cut in a straight line. when cutting a wine bottle the top it cutting straight but the bottom it not.
    Sergeant:
  • 468 Answers
Cutting a glass on band saw is like cutting a metal. You have to make sure that you set up the band saw correctly, get a good quality blade, run on right speed, enough coolant and feed the material nicely.
Posted on Oct 22, 2013
4 Suggested Answers
redbeard00
  • 957 Answers
SOURCE: Cutting straight
The tension on the blade. the position of the guide rollers, and the condition of the blade are all important to get a straight cut. You might want to try lowering the guide rollers down close to the wood being cut. good luck.
Posted on Apr 26, 2009
brewerstool
  • 141 Answers
SOURCE: cutting straight
No blade is going to cut perfectly straight. You have to adjust your fence for drift. Using a test piece of wood maybe 10" with a flat edge and marked to the width you want to cut work it into the blade about half way then stop your blade. Mark the edge where you are going to put your fence with a pencil. It will never be 90 degrees to the blade. Good luck. I use a Delta bandsaw and I do not use a metal clamp fence. I made my own fence that way I can clamp it where I want. You can find plans online to build one yourself.
Posted on Sep 16, 2009
  • 190 Answers
SOURCE: Hi,my bandsaw will not cut a straight line with or
Dave, this could be caused by a couple of things.
One, the blade tension may be too low.
Two, and in conjunction with #1, the blade guide on the left side of the blade may need to be brought closer to the blade ( but without actually touching).
Three, is thee any blade damage that could be pulling the blade to the left? Try another blade and see what results you get.
If you need help determining if one or more of these issues are the problem you're experiencing, or if you need help making the adjustments, you're welcome to send photos of your machine and I can walk you through it.
DIYpro
Posted on Apr 27, 2011
How to make wine bottle windchimes
17 steps to make wine bottle wind chimes -
1. Gather empty wine bottles, ideally, you're are going to need at least 3 bottles.
2. Remove labels.
3. Wash the bottles.
4. Grab a glass cutter and score around the bottle using a
clamp as your guide.
5. Cut 3 bottles and sand the sharp edges to prevent cuts.
6. Get 3 corks.
7. Acquire 6 3/4 hooks.
8. Buy at least 2 feet (0.6 m) of jewelry chain.
9. Screw the hook on top of the cork.
10. Attach the chain to the hook.
11. Push the cork back on top of the bottle.
12. Repeat steps for the other bottle.
13. For the last or bottom bottle of the chime get a metal earring or any accessory.
14. Attach it to the chain. this will make sounds as the wind blows into your chime.
15. Accessorize the end of the chain if you prefer.
16. Carefully connect all three bottles.
17. Hang somewhere where air passes and listen to relaxing sound it makes!
Mar 12, 2017 | Furniture
I have a gryphon c-40 diamond band saw and it will not cut a wine bottle in half straight. am I not pushing hard enough or is my blade dull?
Are you using a new blades? If not, try using new or different blade. Make sure that you're feeding the material just nice and slow and you have enough water so that you will not stress the blade too much.
Oct 21, 2013 | Saws
Cork for top on ice cream maker
If you are trying to find a new cork, trim a wine bottle cork or cut a piece of rubber from a large gromet you can find at an auto parts store
Oct 23, 2012 | Sunbeam White Mountain Ice Cream Maker...
Wine in 5th gear
Your transmission has a straight cut 5th gear and not a helical cut 5th gear.
HD fixed this whine with the 2010 touring models.
Aug 11, 2009 | 2008 Harley Davidson FLHRC Road King...
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Adjusting temp
I think your problem is a fuse in back panel has burnt out....you will need to replace it, Tthere are two fuses and one is easy to see and as usual the easy fuse is not the problem, the fuse you need to replace is probably the one in a black shrink rap on top left side of the panel. You will need to cut shrink rap off fuse and find wires. Next step cut and solder in new fuse. I belive the fuse used is a 5 amp 250v, I put in a 6 amp to repair.
Dec 28, 2008 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
Saws Logo
62 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
