Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv-34hs420 and ps3 connected w\ hdmi cable no video
  • 101 Answers
SOURCE: Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
Posted on Aug 27, 2008
SOURCE: HDMI port does not work on the KV-30SH420
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Posted on Jan 20, 2009
  • 252 Answers
SOURCE: Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Posted on Sep 01, 2009
SOURCE: HDMI Video not working on kv-30hs420 but audio works
AmigaDude posts how to reset the video to factory settings here: http://www.avsforum.com/avs-vb/showthread.php?t=766771
The instructions are as follows: 1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Once reset, you'll connect your RCA cables (Red/White/Yellow) and set up the PS3 display settings. To get there from the XMB bar, go to Settings > Display Settings. You might have to disconnect the HDMI cable from the PS3 before the RCA cables work. I don't remember entirely.
Select Video Output Settings > HDMI > Automatic. If you can see the prompt about a max resoultion of 1080i (with your HDMI cable plugged in) you should be good. Select Yes and press X to continue. You can set up the audio but it's not necessary. Select Finish and you should be good.
Posted on Sep 10, 2009
mrstan
  • 242 Answers
SOURCE: My KV-34HS420 won't come on and the Standby light
The system has found issues with your TV.. The only solution is to call in service. Tell them the 6 blinks.. it is a code for diagnostics. Sorry.. the logic portion of the TV is experiencing some kind of breakdown. The only suggestion that I can offer is to hard reset your TV to factory settings.. other than that you are in duck soup..
Sorry...
Stan Skaggs
Posted on Oct 19, 2009
How do i connect my sony tv to my labtop
You should provide all the details about the video out and video in to both the devices, I mean, the configuration details, system, and so on.
Jan 03, 2014 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv-34hs420 w\ ps3 hdmi connection g5et sound but no video
Have you tried a different video cable? If its not a physical issue then it may be a compatibility issue. See if the TV and/or PS3 need a firmware update. Let me know if you have any further questions.
Oct 21, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Connect PS3 to Sony Trinitron. We connected with the PS3 provided AV Cable to the front Audio/Video jacks but cannot get a picture on the TV screen. Not sure what we are doing wrong.
easy breezy fix, you have to force the ps3 to acknowledge that tv is not hdmi, it is just hd. press and hold power button for 5 seconds on ps3 until you hear 2nd beep and let go. settings will come up for ps3, switch to hd. done
May 22, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Jul 12, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
