The receiver is stuck on standby when plugged in to the mains. This was a gift so I have never had the remote control. Pressing any of the function buttons has no effect. Is there a way to get it off standby without a remote?
    Master:
  • 482 Answers
Where is the power button?
Posted on Oct 21, 2013
Testimonial: "Bottom left on the unit"
  • 1 more comment
  • Greg warden
    Greg warden Oct 21, 2013
    The model is sa-gx350
  • jl rad Oct 21, 2013
    here is a page that has the users manual. http://www.manualslib.com/manual/535242/...
  • Greg warden
    Nothing working still, but thanks for the link. Very helpful
SOURCE: avr 1804 denon 7.1 reciver
Did you check the Audio-Video slider button in the middle of the remote? It needs to be on Audio, else the remote sends video channel number signals when you press the numbers.
Posted on Jan 09, 2008
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
  • 20 Answers
SOURCE: I have a fisher ca-9145 stuck in standby and have
Try disconnecting the speakers and powering up the unit. If it powers up normally there may be an issue with your speakers. When most amplifiers first power up they perform a check on the speakers making sure there isn't a short or a blown driver. If a fault is detected the system will stay in standby or not power up at all. Some more sophisticated amplifiers will display what the problem is.
I suspect in your case however there may be an internal fault needing the service of a skilled technician. The cost of repair of such a fault may be more then the price of a new unit.
-Good luck.
Posted on Apr 19, 2011
dunnbiker
  • 8546 Answers
SOURCE: Kenwood KRV6030 Home Receiver - Dolby Surround -
So, if standby is always ON, do you get ANY sound? Or was the right speaker symptom a precursor to the total outage? There might be a clue there.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The remote is available on eBay...
http://cgi.ebay.com/Kenwood-Remote-RC6030-KRV6030-/370485539582?pt=LH_DefaultDomain_0&hash=item5642a8b2fe
Posted on May 04, 2011
msenin
SOURCE: Once after turning on, my Onkyo TX-SR605 receiver locked in one status and does not react on any frontpanel button pressing or remote control. How I can unlock it?
Try pressing and holding DVD button and pressing power button. It should reset it to factory settings.
Posted on Nov 24, 2012
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
Feb 15, 2013 | LG MKJ42519615 Remote Control
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
I have a ev205 yamaha violin its covering of the bridge is damaged how can i solve this problem the black covering is sliped off from the wooden bridge plzz help me
Instructions
Jan 13, 2013 | Motorcycles
Afstand bediening werkt niet meer
Step 1:
Check the light on the remote
, press a number. If the light is on, go to step 4. Not light, then go to step 2.
Step 2:
Check the batteries
Make sure the batteries are full and correct in the remote control. If the batteries are full and correct in the remote control, but the remote still does not work, go to Step 3.
Step 3:
Connect the metal parts
Note:
The lower steps are only for the short remote control, see Fig. Do you have a long remote, go to step 4.
  • Take the battery cover
  • Connect the metal parts with a screwdriver or paper clip.Replace the batteries and check that your remote works again.
    It may be that your remote control needs to be reset for use with your TV.
    Step 4:
    Restart the TV receiver
    • Turn on the television receiver in standby mode by pressing the i-TV (top right).
    • Leave the TV receiver 30 seconds as they are.
    • Unplug the TV receiver from the mains.
    • Plug after 10 seconds into the socket.
    • Turn on the TV receiver by pressing the i-TV (top right).
  • Porsche Parts
May 27, 2012 | Denon Televison & Video
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
Bush digital terrestrial receiver dfta 11
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Mar 09, 2008 | Televison & Video
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
55 people viewed this question
 Grubhead
Grubhead
