Question about Husqvarna Viking 1
Husqvarna Mega Quilter. After using the thread cutter the bobbin thread will not pick up to continue sewing.
    New Friend:
  • 26 Answers
  • Remove the needle plate and clear out any stray threads that might have gotten caught in the mechanism.
  • Brush out any fluff at the same time.
  • Take the opportunity to put one drop of oil on any of the moving parts while you have the needle plate off.
I have a Pfaff GrandQuilter, which is an identical machine and this was the problem.
The other replies are equally helpful IMHO.
Posted on Mar 29, 2015
  • 92 Answers
Sometimes the cutter doesnt leave a long enough tail to start sewing, and the needle wont pick it up, use a diferent thread in bobbin, sometimes thats the issue, or manually extend the thread from the bottom and then start sewing, it will pick it up then
Posted on Oct 21, 2013
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 371 Answers
SOURCE: Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Posted on Sep 26, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
Posted on Nov 02, 2009
  • 111 Answers
SOURCE: I have an husqvarna #1+,
Are you using a different bobbin when you try embroidry? The machine forms the stitches the same exact way when you either sew or embroider. It's just that the hoop moves the fabric. Maybe your bobbin thread in not flowing out of your bobbin case freely. Maybe the type of stabilizer your using is the problem. Maybe your not hooping your fabric tight enough.
Posted on Apr 29, 2011
SOURCE: Husqvarna mega quilter is bunching bobbin thread
try a new needle
clean these areas,,under needle plate,,,bobbin area
check to make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted correctly
Posted on Aug 02, 2011
My nedle on my husqvarna mega quilter will only pick up the bobbin thread through one thickness of fabric and not through all three layers. Suggestions?
Try a brand new needle. A dull or bent needle will frequently not pick up bobbin thread. Also, be sure you are using a needle type that is suitable for the thread and fabric you are sewing, ie if you are sewing woven fabric, use a sharp needle, not a ball point or jersey needle.
All About Needles
If you are still experiencing problems, it could be a timing issue. Take it for service.
Oct 25, 2016 | Husqvarna Sewing Machines
Which direction should the bobbin move when pulling the thread in the HV Mega Quilter 18x8? Clockwise or counter?
Hello
Hold the loaded bobbin case in your left hand and gently pull on the thread. The bobbin will rotate clockwise when correctly loaded.
I'm also sending a link to page 17 of the manual for fututre cross-reference.
http://www.manualslib.com/manual/636967/Husqvarna-Mega-Quilter.html?page=19#manual
Happy quilting!
Jun 01, 2014 | Husqvarna Sewing Machines
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
Husqvarna viking megaquilter thread breakage
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
May 10, 2012 | Husqvarna Sewing Machines
Husqvarna mega quilter is bunching bobbin thread when quilting. Top thread looks fine. I have tried adjusting tension. what should I look for?
try a new needle
Aug 02, 2011 | Husqvarna Sewing Machines
I have a Viking Mega Quilter. The bobbin thread is sewing properly for a few stitches and then does a loose stitch and then a few good stitches and a loose one again, etc.
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
thanks for using fixya..
Jun 23, 2011 | Husqvarna Viking 1
My sister just bought the smaller mega quilter, we are having difficulties when threading machine. we have studied booklet and video and believe we have threaded it correctly. every time we try to sew...
when you sew or use a serger or a quilter machine have a long thread tail of 3-6 inches & make sure the tail is pulled behind the needle
happy quilting
Nov 03, 2010 | Husqvarna Sewing Machines
Bobin thread wads up. I have a viking mega quilter and frame. I have removed all the threads several times, but each time I try to quilt, the cruise control can only move about an inch, and the bobbin has...
just a thought but maybe your bobbin thread is wound on to loose,try to rewind it holding onto the thread to give a tigher tension while going onto the bobbin
Dec 20, 2009 | Husqvarna Viking 1
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Sewing Machines Logo
129 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
