Question about HP LaserJet 1020 Printer
Avery labels set
When trying to print avery labels template 5202 (file folder labels) I get the message "The document page size is set to a custom form that may not be supported by this printer driver" How do I correct this?
    Champion:
  • 411 Answers
Try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Posted on Dec 17, 2013
3 Suggested Answers
SOURCE: Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Posted on Mar 17, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Posted on Feb 03, 2009
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
Hi. We are trying to use an avery label 22807 and also 22806 for a label factory logo we created. We need measurements/diameters so that we can print on these labels. They keep printing wrong. ...
If you are using Microsoft work to print the label, then follow the link below to Avery's website. The link is to their find a template, type in the label number in the Product # or Keyword search box and it will take you to a down load for that label. Click on the download, you will be asked for some information before the download begins. Follow the instructions on the next page (save the file and remember were you saved it). When you open the saved file it will be in Word and you can go from there.
http://www.avery.com/avery/en_us/Templates-%26-Software/Templates
I hope this helps you out.
Jul 22, 2011 | Computers & Internet
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Dec 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Problems with avery mac label expert
To reset the size in your printer to the correct A4 size, do this:
Go to your Applications folder on your hard drive.
In it, you will find a Utilities folder.
Inside that folder, you will find a folder called "Printer Setup Utility."
Inside THAT folder, you will find a list of printers you have connected to your Mac.
Click on one. You will see, at the top of your screen, a set of menus. Click on the "Printer Setup Utility" menu at the far left.
Choose "Preferences" from the drop-down list.
You will see a dialog box with three options: Printing, Sharing, and Faxing. If Printing is not automatically displayed, click on the Printing tab.
At the bottom of the Printing dialog box, you will see another pull-down menu: "Default paper size in page setup"
Choose A4, or whatever size you wish.
Close up all the boxes, and print your labels to your heart's content.
When you're done with your labels, don't forget to repeat this process to switch your printer back to your ordinary size paper.
Hope this helps.
-lizwb
Apr 18, 2008 | Computers & Internet
HP LaserJet 1020 Printer Logo
285 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
