Question about Mcintosh MC7205 5-Channel Amplifier
I need to get replacement glass panel, power and meter knobs and bulbs for mc7205. I'm in Korea and I don't know where to get them. It seems that I can't get them through official mcintosh dealer in Korea because that model has never been officially imported.
Check at a glass fixer
Posted on Oct 21, 2013
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: ALL PANEL AND METER LIGHTS STOPPED WORKING
Well , that looks like a lose connection.
The Amp must be taken apart, and then you check the connector to the front panel. Ensure has contact and there is no oxide.
Also check that there are no bad solder joint, both on panel and on the board, near to where the panel hooks up.
The panel may also fail because of overvoltage if you have a different faulty component on board, like a blown or defective capacitor for example.
The unit can be fixed with a good technician working on it at component level for a couple of hours, apart components, I do not think there is any part to replace.
Posted on Jan 11, 2009
  • 15 Answers
SOURCE: Panel lamps for Mcintosh MC352
You can get an upgrade to LED light instead from
http://www.audioclassics.com/
This would be a great option.
Posted on Jul 27, 2010
Need to know how to replace my bulb for my mitsubetshi mirage car
These covers are water tight,slide a small flat bladed screwdriver between bulb and cover ease all the way around it should slide off.When refitting put a smere of oil on the rubber and slide on.Don`t touch the bulb glass it will just blow!Good-luck....
Jan 05, 2013 | 2001 Mitsubishi Mirage
I need to change lamps in McIntosh MC7205 Amplifier
First off before you do it is a specific bulb custom sized. I cannot stress enough how important it is to use the correct bulbs for this application. If you go the cheapy way it will COST in the end. There is a reason for it. I recently had one someone brought in that used the incorrect bulbs and burned the blue to a horrible brown and blue away from the face as well as melted the face a little. Spend the extra and get the bulbs from McIntosh It was a three hundred dollar repair job. You will save by getting the correct bulbs and doing it yourself. I hope this helps pointing the way to save lots of later frustration.
Sep 29, 2012 | Mcintosh MC7205 5-Channel Amplifier
I need to replace old 60-watt incandescent light bulbs in fixtures that are covered by glass domes. A hardware store man once told me that the new fluorescent bulbs would not be good because they...
you could go and get led light to fit them, they are very good and they give off very little heat, a little expensive but in the long run it will be better than the currly q lighting
Aug 22, 2011 | Verilux Home
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
License plate light is out where do i look for a fuse or does it have a fuse or do i just change bulb
I don't know if that bulb has a dedicated fuse or shares one with the tail lamps (for example)
But if you remove the bulb, you can test it with a continuity meter.
If the bulb is NOK, replace it.
If it is OK, then there is possibly a bad connection in the socket or, as you suggest, blown fuse.
But I would expect a blown fuse also to have stopped other items working.
May 10, 2011 | 2004 Chevrolet Impala
Fog/driving light bulb replace
There is a panel under the corners of the bumper that is held by two screws. You can access the Light bulb by removing the panel, careful that when installing the new bulb's. Try to keep from touching the glass and it's a go thing to change both side. Good luck
Mar 14, 2009 | 2003 Pontiac Montana
98 volvo S70 low beam bulb replaced still no light
Easiest way would be to go back to where you bought it and make sure the bulb is installed that you bought....and show them. Ask if you can get a new bulb and change it in front of him. Call the dealership and talk to parts, ask if, indeed the hi and lo are interchangeable.
Mar 12, 2009 | 1998 Volvo S70
Mabe oven thermostat and stove flame adjustments
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Sep 13, 2008 | Kitchen Ranges
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Adding 2 extra channels to pair a MC7205 with a MX119 pre/pro
Yes, you can connect the MX119 'Multi-Amp' output connection to the MC7205 using a 'Parallel' 25-pin cable. It will send Front_L/R/Center/Surround_L/R signals (5 total) to the MC7205, then use a separate pair of RCAs cable to connect the 2 back-surround signals to another 2-channel amp and you are all set.
Feb 09, 2008 | Mcintosh MC7205 5-Channel Amplifier
Mcintosh MC7205 5-Channel Amplifier Logo
116 people viewed this question
Top Mcintosh Audio Players & Recorders Experts
sean tan
Level 1 Expert
 Grubhead
Grubhead
Jay Plesset
Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
