Question about Whirlpool AWM5125/1 Front Load Washer
Front loading Whirlpool AWM5125 spin cycle not working. After washing clothes the machine will not enter the spin cycle. The drain filter has been cleaned and cleared, yet still no spin cycle.
    Sergeant:
    Champion:
  • 257 Answers
Most likely you need to replace the motor control board. You may need a serviceman to confirm this issue.
Posted on Oct 22, 2013
  • 1294 Answers
SOURCE: Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Posted on May 21, 2007
mark_37388
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
SOURCE: Whirlpool WFS1071BW front load washing machine -
Unplug your washing machine and then you will be able to get the door open and the clothes out. You may need to leave it off for awhile to get it to work but make sure you have a bucket ready to catch the water coming out.
Posted on Oct 19, 2010
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle is not working. clothes are soaking wet when cycle is finished.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washing machines spin cycle is not spinning the clothes dry
heatman101
Sep 07, 2010 | Whirlpool Washing Machines
Does not spin or drain
if it doesn't spin or drain then firstly check your drain filter to see if this is blocked and remove anyhing you find. If there is no sign of blockage then your drain pump is broken and needs replacing
Jan 10, 2010 | Whirlpool AWM5125/1 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Awm 5125 front load
I had the same problem tonight!! I opened the filter at the front and found one of my baby sons socks and 81 cents!
The machine is draining away perfectly now, but the floor got soaked when I opened it, so be prepared.
Hope this helps...
Jan 17, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Apr 17, 2007 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
