Question about Beko Washing Machines
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
  • 3 Answers
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Posted on Oct 21, 2013
4 Suggested Answers
  • 6277 Answers
SOURCE: my Beko WMC62W washing machine
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 26, 2011
SOURCE: I have a beko wma620 washing machine. power is
had same problem change the motor brushes and all wil be ok £20 and one hours work easy ....kev......
Posted on May 14, 2010
  • 9 Answers
SOURCE: I have a beko 5140w
check the timer..
Posted on Oct 11, 2010
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
WMB 71642 W won't allow programm set
have you held the start button for ten seconds to cancel the program
Feb 03, 2014 | Washing Machines
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Washing Machines Logo
475 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
