Question about Car Audio & Video
HOW TO GETGOOD reception FROM ANTENNA ON ROOF
    Master:
  • 482 Answers
You must know where your broadcast towers are, so you can aim your antenna at them
Posted on Oct 21, 2013
Why is it only abc tv have a weak quality signal & reception
sounds like an antenna problem. rotate it with someone who can tell you how TV is affected by rotation. Some people buy an antenna motor for reception.
Feb 16, 2015 | Televison & Video
Radio antenna location
the antenna is located in the roof and front fender have included a link to a schematic (basic location) , if not getting a good reception the best solution is to get an aftermarket fit antenna that mounts on the vehicle body because to try and replace this factory fitted antenna would be prohibitively costly
Antenna Amplifier in Electrical Lighting and Body Mobile Multi media...
May 22, 2014 | 2007 Hyundai Entourage Limited Minivan
Why have I no radio reception on peugeot 307?
go step by step to find the fault.
check antenna connection behind the radio
check roof aerial and wire connection underneath it.
Take an old radio's antenna and connect it to your car's radio antenna input and check whether your car radio is working properly.
Apr 15, 2012 | Peugeot 307 Cars & Trucks
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
Poor reception within buildings that are only 30 mtres away. The antena is situated UNDER a tin roof
tin roof acts as a faradyne cage (http://en.wikipedia.org/wiki/Faraday_cage)
Your antenna will need to be outside of the building and then it will work fine!
Mar 28, 2011 | NetGear PROSAFE ANT2409 Indoor/Outdoor 9...
Setting up the TV
You will definitely need some type of areial. A pair of rabbit ears for local reception and a powered set for longer range. But yes you will need an antenna near your TV or a good roof top one. Good Luck and thanks for asking. PS!!!!! Be sure to tell your TV you are looking for an over the air signal!
May 24, 2010 | Televison & Video
Denon DRA 345R. no fm reception.
Hi...
What are you using for an antenna?
Also, do you have aluminum siding or aluminum sheet in your house insulation?
Steel roof? Any of those will kill reception.
Mar 23, 2009 | Audio Players & Recorders
Following an "incident" with an overhead garage door, roof damage was repaired and the antenna replaced by a reputable body shop, but no reception on AM band and limited FM reception on my '03...
remove the antenna and check that it is connected properly. the body work could have resulted in a poor connection.especially the ground connection to the roof itslef.
Nov 10, 2008 | Volkswagen Jetta Cars & Trucks
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
