Question about Schwinn Original Airdyne
My airdyne started to make some funny noise this morning. It sounds like some part of it is rubbing together and I am not sure what it is. Anyone else have this problem?
Hi , my corsa 1.4 I utility does not start on the first attempt only in the mornings when it finally starts there is a noise but as you drive the noise goes away and starts perfect rest of the day so...
I am having the same problem with my Corsa but it does not make any funny noises, it just sometimes wont start first thing in the morning and then is fine for the rest of the day.
Did you find out what was the problem with your vehicle? Did you resolve it?
Any other ideas please anyone
Aug 12, 2013 | Cars & Trucks
Sound from undercarriage when braking
See if the noise is also getting louder as you turn one direction or the other. The rubber rubbing sound doesn't ring bells but I suspect the bearings going out on one of your wheels. If it makes a noise when breaking but get louder or better as you turn one direction or the other I would bet bearings. I would look at that.
Aug 31, 2012 | 2006 Chevrolet Cobalt LS
Wont start funny clicking sound when i turn the key ???
Hi!!
The clicking you are hearing, is the sound of a weak battery, Jump start the vehicle and take it to an AutoZone for a Charging System check.
Good Luck!!
Mar 20, 2010 | 2006 Land Rover Range Rover Sport
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
My dryer just started making a funny noise. It
un plug dryer and take it apart and see if belt come off or broke
Jun 18, 2009 | Kenmore 66942 Dryer
Left Wheel Makes Funny Noise...
sounds like wheel bearings or 4wd might be stuck engaged... try cycling 4wd or checking grease packing first.
Feb 21, 2009 | 1995 GMC Jimmy
Car makes funny noise upon starting on very cold days
Have your power steering belt checked and adjusted, or replaced if worn.
Jan 20, 2009 | 1998 Plymouth Breeze
Squeeking noise when car starts in the morning, when it's cold.
it sounds like it your belts are slipping check adjustments if it has any not sure on this car if the belts are tight you can buy spray from a auto shop to stop the noise hope it helps
Dec 30, 2008 | 1994 Mercedes-Benz C-Class
Squeeking noise from pasenger side rear door
Check your hub spindle(wheel bearings), I had to replace both mine at 70,000 miles, started making this roaring sound and we thought it was the tires. There is no way to grease the bearings, it's a complete sealed part that just wears out, easy to replace.
Dec 24, 2008 | 2001 Kia Optima
Funny noise on drivers side and loss of power during acceleration
ok its a thought off my head that i can think of right off
the brake on drivers side is binding and the squiller pin i call it is rubbing on rotor you probably need a brake inspection there free at brake masters
May 30, 2008 | 1998 Kia Sephia
Schwinn Original  Airdyne Logo
52 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
