Question about Add-in Express Merge Cells Wizard for Excel
Ablebits merge tables not working - Add-in Express Merge Cells Wizard for Excel
Merge rows and columns of table in vb
Under edit there should just be a button called merge cells. Columns you want to merge by holding shift and clicking on them. Then click merge cells.
May 03, 2011 | Computers & Internet
NEED TO KNOW HOW TO PRINT MORE THAN 1 ENVELOPE AT A TIME. DO LETTERS AND ENVELOPES ONCE A WEEK BUT THE PRINTER WOULD ONLY PROCESS 1 ENVELOPE AT A TIME AND I HAD TO DO THAT ONE MANUALLY.
Hi there !
For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
Here's how to create mail merge document file.
1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
6. After that, press preview result to display the datas. Save your work and it is finished
7
Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
How to merge several photos in one
Do you mean make a panorama photo ? Many cameras have a panorama function that does this automatically - it is a special setting. To do it manually use any photo-editing software like Photoshop or free GIMP or free online such as SUMOPAINT. Put each photo on a separate layer and move them around and erase overlapping portions. When all of them appear nicely aligned flatten the layers. If his makes no sense to you do not worry there is automatic photo stitching software, also free - this page tells about it:
http://www.kenrockwell.com/tech/panoramic-software.htm
However if you simply want to make a photo collage you can also do it manually, or use picasa software's create/ Picture Collage function. This arranges selected photos randomly as if on a table-top in one photo.
Dec 16, 2010 | Computers & Internet
Merge 2 columns with 550 cells each all at once?
Merging Columns In Excel Now that we've clarified what merging columns actually means, we can explore how to do it. The first step is to perform the merge for the first cells. Let's go back to our first example and suppose that we are merging column A that contains first names with column B that contains second names. We'll put the merged columns into column C. To merge cell A1 with cell B1 we woul type the following into cell C1:=A1&" "&B1
paste this into C1 (or where needed)
=A1&" "&B1
Jun 15, 2010 | Microsoft Office Excel 2007
When I copy and paste news alerts from Outlook Express to a word doc the alerts are formatted into tables. I want to either re-format so the tables do not show up on the word doc, or make the table...
nxt time whn u copy and paste the alerts> if the table is formed> there is a drag pointer formed on the top left of the table> right click on it > selct merge cells
Oct 07, 2009 | Microsoft Outlook Express
Capitalized first line in table merge
It's burried in the "auto" section of Word. I had this problem with a professor. Check in the "auto" section, it's set to capitalize. Need to uncheck it.
http://office.microsoft.com/en-us/word/HA101747301033.aspx
HA ... there it is.
Jul 16, 2009 | Microsoft Office Word 2007 Full Version...
Sql Server 2005
select n1.name,age,department from int newtable n1,n2 where n1.name=n2.name
Dec 10, 2007 | Microsoft SQL Server 2000 Standard Edition...
Merging Data in 2 Separate Excel Workbooks
If the First Name and Last name are equal to both work sheets, I will just sort them by First Name and Last name and copy the results into a separate work sheet. If the names are different you will have to use Access: This can be easily done with Access and SQL, just import both work books into different tables to access and use the create query wizard, play with the results until you will get the result you want. Access will also solve the duplicate problem easily. Very important: You will have to use join properties: Read help about join properties and understand how this works... Afterward you can export it back to Excel or use Copy/Paste. If you can't use Access and have only Excel: You will have to use Vlookup on various fields until you will get the result you want. Its a hard work but in the end you will get the same result as access. Let me know what happend Daniel
Aug 20, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top Add-in Express Computers & Internet Experts
David Payne
David Payne
Are you an Add-in Express Computer and Internet Expert? Answer questions, earn points and help others
