Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
My external hard drive got a virus had to reformat now computer wont recognize it
It do automatically install drives or software when you plug it in and the computer only recognizes it as local. computer wont let me put anything on it or even try to reformat it again
    Scholar:
  • 135 Answers
I am taking for granted that you are using Windows, not sure which version ( XP , 7, 8 , 8.1 )
and if I am correct, but your computer does not recognize the drive, make sure the usb port is one that will give power to the external drive. You should use USB2 or if available USB3. Those are powered.
Click the Search feature for the particular version of Windows you are running and search for "Disk Management"
Look for the partition of the external drive you are using. It will be given a letter other than C: drive. May be D: E: F: etc etc etc. Sometimes your optic drive is the D: drive, you may need to purchase a program like Everest Ultimate to locate ALL your items on the MOBO.
If your able to find the External in Disk Management, you should be able to format it, rename it, change its functions, etc etc.
Good Luck
Posted on Dec 07, 2014
renx
  • 71 Answers
SOURCE: Toshiba 160 GB Hard drive is not seen by 'new' computer
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
Posted on May 03, 2009
paper bag
  • 72 Answers
SOURCE: My computer isn't recognizing my new Toshiba Roco
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Posted on Dec 26, 2009
jcameo7270
  • 675 Answers
SOURCE: How do I reformat my
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Posted on Dec 25, 2010
bronk50
  • 27725 Answers
SOURCE: MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Posted on Jul 03, 2011
SOURCE: Hello I have a Toshiba
Blue means connected to USB3.0
White means connected to USB2.0
Posted on Mar 16, 2013
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
Hi mate i have a wd passport hd, and i took it out when my computer wa restarting. and now my computer and any other computer dont read it it say reformat. it has very importent files on how can i retrive...
Here is a 10 day free trial of a software recovery program that can be burned to a disk. You would then boot from that disk with your external drive plugged in, and after it loads the software, tell it to find all available files. When you find your files, copy them to your regular hard drive and reformat the external. Copy the files back to your external drive. Hope that helps some.
http://www.ntfs.com/products.htm
May 03, 2011 | Western Digital Passport 320GB External...
My computer wont recognize the drive or allow me to reformat my passport.
Try downloading the device driver from western digital site for your respective OS. And try formatting it with the western digital inbuilt software, which works great.
Jun 30, 2010 | Western Digital My Passport Essential...
My windows explorer stops and restarts please help me to solve the same
It's possible that it's a hardware problem or your computer is infected by a computer virus. Does it restart when you see the windows XP logo or when you are in the desktop? or Does it restart before seeing the windows xp welcome screen? Since this is a laptop it may be hard for you to reseat some of the internal devices inside in your laptop so we could start isolating the issue from the hardware and to the software.
First try to power cycle it, turn off your laptop remove the battery, any external connection like external mouse, external hard drive and monitor and press the power button for 15 seconds after that put the battery in and turn it back on without the external devices plugged in. (if it turned on without a problem that's good-possible that one of the external devices are causing it to keep on restarting, to isolate it you can just put the external devices one-by-one and start the computer, if it start occuring you know who is causing the problem)
If you can disassemble your laptop you can try to remove the hard drive, then turn on your computer, if your computer didn't restart that means that the problem is with you hard drive, possible that the software installed in it is faulty or the hard drive itself (try plugging it back in properly let's see if it'll work, if not, you may need to buy a new hard drive or before buying one, you can try to plug your hard drive to a different computer (acting like an external hard drive) and backup all your important files and reformat that hard drive, after reformatting it you can try to plug it to your laptop again. (if that hard drive is not detected to another computer meaning that it's faulty)
If that didn't resolve the problem, you can try to reseat the memory testing each memory chip and slots, processor.
Hope this help.
Jan 11, 2010 | Acer Extensa 4620-6402 Notebook
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Computer stopped recogn drive after install utility progrm
you will probaly have to buy some expensive software to get your data back. or just reformat.
Nov 26, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
My laptop cannot recognize my external cd rom
Need to go to the hard drive maker website and look for a driver and install it to your computer search for the model # on the website of the hard drive company
Jan 31, 2009 | Toshiba (PX1052E-1NMD) External 24x CD-ROM...
Device Not Recognized in XP
Ok, the drivers are located on the drive itself, which sounds crazy I know. However, try going to My Computer and look to see if the drive happens to be there. If not, try plugging the drive into a USB port that you know works. Still nothing? Reboot the computer and try again. Also, you may already have the instructions below (from WD's website).
Important: For highest performance and reliability of your Western Digital hard drive, we recommend that you install the latest service pack and updates for your computer hardware and Operating System.
For Windows Millennium, 2000, and XP:
  1. Turn on your computer system and allow it to boot to the desktop.
  2. Connect the power cord and USB cable to the external hard drive.
  3. Connect the USB cable to an available USB port on the computer system. The external hard drive will turn on automatically.
  4. Drive utilities and device drivers are installed automatically during the installation of the drive. If a security alert is displayed during the installation process, click on Accept or Continue.
  5. A menu will then display a list of bonus software utilities from Google™. Double-Click the Google™ options to begin installation; otherwise, click Quit to close the window. When finished, the hard drive is ready for usage and will be shown as a new drive letter under My Computer and Windows Explorer.
Dec 22, 2007 | Western Digital My Book Essential Edition...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
