Question about Diamond Products 01738 Core Bore Weka DK12 Drill Motor
Need to rewire the handle on a weka DK12 core drill
The drill shuts off when cord moves.
What has likely happened is one of the wires, white or black, inside the black plastic electric cord has fractured.
This is really common on electric hand tools that are either over 5 years old or are well-used.
I can't count how many times it has happened to me!
You will need to somehow cut the cord off at the bad spot, and rewire the end of the cord into the end of the drill handle.
Won't be easy, but you can do it.
Many more modern tools have a reinforced sleeve of about 2 inches at this weak spot.
God bless your efforts.
Apr 07, 2016 | Drills
Type your problem for a solution...no power
Check the brushes: they should be over 1/4" long, the springs should be intact and pushing the brushes into the armature and they should slide easily in the brush holder. Using a volt meter, check that you are getting full power to the switch. Next check that power is getting through the switch when the swtich is held on. If all of these check out you may have shorted or burnt windnigs on the armature or field.
Jul 19, 2012 | Makita 6013BR 63Amp 12Inch Drill with Top...
My drill press runs backwords
was this drill press recently rewired or had a switch installed. The only thing I can think of is that it is wired incorrectly. Recheck the wiring. Let me know if you need more assistance. Usually on the motor cover there is a wiring diagram for the proper voltage and rotation.
Mar 15, 2012 | Drills
The keyless chuck on my Makita HP2071F Drill (mains supply) is damaged. How do I replace it?
Open the chuck up fully, and in the bottom there is a reverse threaded lock screw that needs to be removed. (drill it out if you have to, it can be really hard to retrieve). Insert an allen key into the jaws of the chuck and hit the handle with a hammer to turn the hole chuck anti clockwise, firmly and quickly. Replacement is reverse but not so dramatic. Sometimes the chuck is damaged in such a way that it will not grip an (large) allen key sufficiently. You can then peel of all plastic parts of the chuck to expose the core. From here you can weld a metal pice to the chuck in place of an allen key. Take care not to damage the threaded axle from the gear.
good luck
Feb 25, 2011 | Makita & 1/2 Inch Drill
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
After drilling a hole with a 14" long 1" bit...the drill ceased to work...I've also had the same problem with 2 other drills(both bosch), where one of the 2 doesn't work on hammer anymore because the...
need to check the hamer piston. also if your switch is going out are you useing a long cored (yellow) need a cored rated no less than 15amp 50'. to long burns the switches out ever time. let me know I'll check my manuels. good luck
Oct 12, 2009 | Drills
Rewireing 93 harley davidson FXLR to 96 Handle bar
On the handlebar switches, Harley hasn't changed the color code scheme very much over the years but you really need a good schematic to know exactly how they are wired up. If you can find either a Harley service manual for a 96 model or a Clymer's manual, it would be helpful. I have a schmatic for a 94 FXDWG that should be alright for your 93 FXR but you need a schmatic for a 96 model bike.
Oct 07, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Rewiring, changing ape hanger handle bars to std
Try looking up Powersprtseast.com They have a parts fische you can use and though not in color itself may have colors labled on diagram for wiring harness.
Oct 02, 2009 | 2001 kawasaki VN 1500 Vulcan Classic
Data mining
Hello, you can find the best open-source implementation of data-mining algorithms here:
http://www.cs.waikato.ac.nz/ml/weka/
You can use the built-in application or embed it in your own code.
Of course it implements several naive bayes algorithms
Mar 20, 2008 | Computers & Internet
Diamond Products 01738 Core Bore Weka DK12 Drill Motor Logo
70 people viewed this question
Top Diamond Products Drills Experts
Are you a Diamond Products Drill Expert? Answer questions, earn points and help others
