Question about Sony KV-32FS13 TV
My tv its a sony a big screen with a big box underneath an hold the speakers in side the box..an the problem is! MY TV KEEPS TURNING ON AN OFF LATELY AND IT WOULD BE FOR A CERTAIN TIME.it would take 30min then20min then after that! it gave up an turned off..i turned it back on the screen turn yellow and the timer/standby has been on ever since we got the tv..today its been bleaking the hole day!.. my boyfriend told me to turn off breaker the turn off an on tv ... an nuthing has worked.. i left it off for 40min the volume sounds with the screen black but then turns off again! i need help please help me!
    Sergeant:
    Champion:
  • 375 Answers
Requires service ,possible solder connections in the deflection and video sections ask for an est. cost of repair
Posted on Apr 16, 2008
3" shadow on left side of screen
watch for speakers being to close to the tv. if a speaker has a big magnet on the back of it, it will cause it to have the shadow and then it will turn green. so make sure there is nothing with a magnet close to the tv because it will ruin the tube on the tv.
Apr 10, 2012 | Panasonic TCP50S2 50 in. TV
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony KV-32S42 (See Description)
It may be a fruitless effort. The main reason this occurs is that the Picture Tube is drawing too much current and the AKB circuit will not let the video circuit diplay the picture. Outside
of replacing the Picture Tube there is no fix.
You can varify this by turning the screen control up. This is usaully located on the HV transformer and is marked. the other location it may be is on the CRT board. It also would be clearly marked. If you adjust this slightly and the picture appears, the Picture Tube is the problem. I'm betting 100% it's the Tube.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony KV-32S42 32" TV
Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Mar 26, 2009 | Sony Televison & Video
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
TV screen won't turn on only sound
Good day, cjnewcarguy;
If you like new cars you may enjoy a new LCD Flat Panel TV. Try unplugging the TV for about 2-3 minutes, plug back in. Working... no?? The average repair cost of projection TV is about $400.00 to $550.00.
Good luck, big IRISH.
Jun 23, 2008 | Sony KP-53S35 53" Rear Projection...
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green spot on the screen.
is there a speaker from a stereo player near the set? i noticed mine give my tv a greenish tint on the side of the tv closet to the speaker
Aug 05, 2007 | Sanyo HT32744 32" TV
Sony KV-32FS13 TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
