How do you add transmission fluid to a 1999 oldsmobile alero
    Master:
  • 483 Answers
Into the same place that you check the transmission fluid level
Posted on Oct 21, 2013
Where do I add transmission fluid on a 2002 Oldsmobile Alero?
Use a funnel and pour in the fluid into the transmission dip stick tube. Do it slowly so you don't overfill.
Jun 16, 2014 | 2002 Oldsmobile Alero
2004 olds alero transmission fluid how much to fill up
fill it to just above the low level , check it while it is running, (in park) ;-) on a level surface. drive it around the block to warm up the trans, check it again, if it is still low then add some to the full line, check again while running. (don't add fluid when running) it should stay at the full mark at this point.
Apr 05, 2013 | 1999 Oldsmobile Alero
Transmission fluid hose burst, fixed it, add fluid now the car won't move...
Two litres? Unless you are outside the USA, transmission fluid generally comes in quart containers. If you only added 2 quarts, yes, it's very possible the fluid level is low. However, you don't want to add too much. There should be a dip stick for checking fluid level. Run the vehicle until the engine is good a warm, about 15-20 minutes, and then check the fluid level. Add as needed. But remember, don't add too much. Add a little at a time, as you get close to full.
Feb 05, 2013 | 1999 Oldsmobile Alero
Transmission fluid level 1999 alero
What do you need to know?If your car is a automatic transmission,then start and let warm up and put in park and check while running,if low,turn off and add,then start and check,use funnel at dipstick hole.If manual transmission,there's a plug on side of transmission,remove plug and see if you can see fluid,put finger in to feel,to add,get a turkey baster,dollar store has them,fill till it comes out.The drain plug is under transmission.
Feb 04, 2013 | 1999 Oldsmobile Alero
No drive on a 1999 olds alero
CHECK TRANSMISSION FLUID SOUND LIKE VECHICLE SLIPPING DUE TO LACK OF FLUID. CHECK TRANSMISSION FLUID ON DIP STICK. WHILE ENGINE COLD FLUID LEVEL ON DIP STICK SHOULD FULL MARK.CRANK ENGINE LET VECHICLE IDLE TO WARM.THEN HOLD FOOT ON BRAKE SHIFT THROUGH ALL GEARS FEW TIMES CHECK TRANSMISSION FLUID LEVEL IF LOW ADD FLUID UNTIL YOU GET TO FULL MARK.IF YOU HAVE THE TRANSMISSION WITH NO DIP STICK.YOU NEED TO CHANGE TRANSMISSION FLUID + FILTER. YOU NEED 7 QUARTS OF TRANSMISSION FLUID.BUY DEALERSHIP TRANSMISSION PAN GASKET ITS THICKER MADE DIFFERENT WONT LEAK FLUID. THE TRANSMISSION GASKETS AT AUTO PARTS STORES TOO THIN LEAK FLUID BAD.
Nov 09, 2010 | 1999 Oldsmobile Alero
How do you check the transmission fluid on the alero ? i can not find a dip stick
TRANSMISSION DONT HAVE A DIP STICK.IT HAS A RED FILLER CAP INSTEAD.TO CHECK TRANSMISSION FLUID THE CAR HAS TO PUT ON A LIFT LEVEL.TRANSMISSION HAS A CHECK PLUG.ITS UNDER THE EXTENSION HOUSING.THE OIL PAN DRAIN PLUG IS BELOW IT.YOU NEED A DRAIN PAN AND THE CAR NEED TO BE RUNNING AT OPERATING TEMPERATURE.WITH ENGINE RUNNING YOU REMOVE THE CHECK PLUG.IF NO FLUID DIPS OUT YOU NEED TO ADD SOME FLUID.IT FLUID POURS OUT YOU HAVE TOO MUCH TRANSMISSION FLUID IN SYSTEM.IF YOU GET A SLOW DRIP YOU HAVE THE CORRECT AMOUNT OF FLUID IN TRANSMISSION.THE CAR HAS TO BE LEVEL AND YOU PUT FLUID IN THE TOP OF TRANSMISSION WHERE THE RED VENT FILL CAP IS.YOU NEED A LONG LONG FUNNEL TO PUT FLUID IN WITH OUT SPILLING FLUID ALL OVER THE PLACE.
May 08, 2010 | 1999 Oldsmobile Alero
Where do I add the fluid for the Automatic transmission for a 2004 oldsmobile alero 3.4 v6
Take out the transmission dipstick and carefully pour in as much as you need in the tube.
Dec 30, 2009 | 2004 Oldsmobile Alero
Do not know where to add transmission fluid
Automatic transmission fluid is aded through the dip stick hole using a funnel.
Apr 28, 2009 | 2002 Oldsmobile Alero
Computers & Internet Logo
David Payne
David Payne
