Question about Lands Phones
Phone only rings once then cuts off have to press call key twice to receive call
  • 4 Answers
Do you have Call Forwarding active (even if accidentially)?
Posted on Oct 21, 2013
Already have unplugged everything twice and still will not accept incoming calls. The phone rings once and cuts off. Sometimes the single ring is heard only on the outgoing phone not on the incoming call...
Try reset the phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 22, 2011 | Cell Phones
Line is on "no lines rings"
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Sep 22, 2010 | Lucent PARTNER18 Corded Phone
How do I turn off the local ringer on my office phone, AT&T MLS12D
Press the right hand intercom once. The display should say Centralized Programming.
Apr 29, 2010 | AT&T Lucent MLS-12D Phone
Ring options
Sep 26, 2009 | Lucent PARTNER18 Corded Phone
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
I can't receive faxes
if this is @ your home it might be sharing a house phone, or check with phone company to see if there any speical features on your line, call and check the line,your fax line need to be a stand alone
Feb 04, 2009 | Brother Multi-Function Center MFC-240C...
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
Ring tone off
Press the Function key (bottom of handset, black button that says Mute but has Function underneath)
In the silver button, in the top middle of the handset, press the down arrow button twice and display shows Ringer setting.
Press the right arrow key, then use arrow up and arrow down to adjust volume level. when you're done, press the right arrow button to SAVE.
Jul 27, 2008 | Panasonic KX-TG2382 Cordless Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
