Question about Vitamix 5000 Work Top Blender
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
  • Vitamix Master
  • 1,318 Answers
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Posted on Dec 05, 2013
Testimonial: "Thanks for your assistance. Very much appreciated."
Moisture vitamix container bottom
Your canister/pitcher is leaking?
It is probably blade assembly & bad seal.
You will need a special wrench to correct this.
check here:
Contact Us Customer Service Vitamix
Or here:
Vitamix Wrench
May 24, 2014 | Vitamix Blenders
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
My vitamix4500 leaks
Your container may have a bad seal at the blade assembly??
You will need a special wrench to remove it.
check here:
Or here:
Amazon com vitamix wrench assembly Home Kitchen
Feb 24, 2014 | Vitamix TurboBlend 4500 Work Top Blender
Vitamix container ensambly
What do you need to know?
container leaking? Not spinning right?
Just change the assembly...
check here:
Feb 02, 2014 | Vitamix Blenders
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Jan 30, 2014 | Vitamix Blenders
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Leaking blender jar
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Mar 20, 2011 | Vitamix 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
226 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
