My sennheiser cx 299 headphones, cannot hear out of the left ear plug help me plz
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
  • 1138 Answers
SOURCE: no sound from headphone
Worse case scenario is that your left speaker is gone but usually what happens is a break in the cable someplace.Are you using the 1/8" plug or are you using them with the 1/4" adapter. The 1/4" adapter might be worn out but is easily purchased and replaced.The cabling from the plug runs into the left can and from there splits into left and right speakers. There will be a wire that follows the head band under the cushion from left to right. With these headphones there is a swivel above the can and the problem might be in there. Half the problem is getting at the wiring to test it. Usually the plate that the speakers are mounted on is screwed to the back cup and the screws can be reached by removing the earpad. You will need a volt ohm meter to test the wiring. You can also test the speakers with it. Unfortunately most plugs on headphones are molded onto the cable so you will have to start by testing from the plug to the left can. Inside the left can will be a junction point where the main cable feeds the right speaker. Test up to there for right and left and if the connections are good then test the speaker. Hope this helps.
Posted on May 14, 2009
  • 1138 Answers
SOURCE: how do u fix a disconnected wire in a left ear
Try this link:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Posted on Oct 28, 2009
coldtoon
  • 51 Answers
SOURCE: The left ear of my
one or more of three things might have happen 1. the wire came off the speaker itself 2. the wire has been crushed in some part along the line in some shape or form 3. the wire came off the headphone jack in terms that it was built weak and ment to break to get you to buy more. In all three cases it just takes a bit of soldering and black tape.
Posted on Mar 03, 2011
Why have I lost volume in one ear
there will be some loose connection in wire...or else u may have dropped down the earphone....maximum it will be wiring problem....
Aug 20, 2014 | Sennheiser Genuine Cx270 Cx 270 In Ear...
I have the sennheiser cx 380 orange sport in ear headphones. The cord where it attaches to the metal plug has pulled apart in a way that the metal plug can pull away but the cords are in tact. And now the...
I think this is common problem for headphones. To fix it you will have to solder cord's wires back to plug. If you have tools and some experience you'll be fine
Aug 17, 2011 | Sennheiser Audio Players & Recorders
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
My earphones have stopped playing music. It just started in the left ear, now it doesnt play in either. Can this be fixed?
try using other headphones to your unit, if it plays, the problem is in the CX400 indeed. usually caused by unintentional yanking & other factors, the internal of the wires were broken, it can be fixed yes, with patience and some soldering skills, just find the appropriate cable for that particular model, with imagination you can even use other headphone cables, ;-)
Feb 03, 2011 | Sennheiser CX 400 Headphones
When I used these headphones this morning, I noticed that the sound from one of them was far less powerful than the other one. I've tried different songs, to see if it wasn't just the song, but the problem...
had the same problem with the right ear bud and I don't know if it is suggested in the manual, but cleaning the mesh on the ear bud with a cotton stick dipped lightly in alcohol (almost dry) helped with me, the sound is back 100%.
I hope it helpes with your too.
Mykab
Sep 05, 2010 | Sennheiser CX 300 Consumer Headphones
Help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Mar 17, 2009 | Sennheiser CX 300 Consumer Headphones
70 people viewed this question
 Grubhead
Grubhead
