Question about Gorenje GV 62110 23 in. Built-in Dishwasher
Gorenje 62110 Will not start. Salt light has come on. Have never needed to use salt in the past. Have put salt in but will still not start or allow to choose a program.
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
Jun 30, 2010 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
The salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Mar 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Gorenje GV 62110 23 in. Built-in Dishwasher Logo
41 people viewed this question
Top Gorenje Dishwashers Experts
Joseph Hoffmann
richie46
ray gallant
Are you a Gorenje Dishwasher Expert? Answer questions, earn points and help others
