Question about Sanyo DS13204 TV
TV turns off
My Sanyo TV turns off after 5 min. Plus the picture is off center.
  • peacegame98 Jan 01, 2008
    i have the same problem it stays on for about a 1 to 2 minutes at first then as it warms up it seems to be more like 10 seconds until it wont stay on
Where can i get the parts and a manual?
Posted on Jan 15, 2008
  • 67 Answers
Replace the memory ic (IC802) if the memory no data contact me ill give you the whole data, service mode
Posted on Sep 29, 2007
SOURCE:
I HAVE SOUND AND CABLE CANNEL BUT NO PICTURE. IS THERE A RESET FOR THE PICTURE. THE TV IS A 2010 SANYO 42" MODEL DP42840
Are you on cable or satellite? You'll need to reset the receiver box, not the TV, and if that doesn't work, call your cable or satellite service.
Dec 01, 2014 | Sanyo Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Sanyo dp55441 - wont come out of sleep mode. every hour a msg comes up tv will turn off in 1 min. how do i turn this off? pls and thank you
hi go into the menu on the tv scroll down to picture setting look for sleep timer select off
regards
shaun
Jan 31, 2014 | Sanyo Televison & Video
46" LCD HD TV no picture until 20 min after being
Check the video module see if you can resolder the components, the tv have some loose connection in that video section and in the power supply.good luck.
Oct 04, 2011 | Sanyo 42 in. LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Turn tv on off plus code for sanyo crt tv
Try one of these, 017,023,027,038,066,080,091,098,123,125,126,202,203,205,206,207,208,209,210,211,154,159.... hope this helps..
Mar 19, 2010 | Sanyo DS31520 31" TV
Sanyo TV buzzing
may be a problem with power supply.
Nov 14, 2008 | Sanyo DP42746 42 in. Plasma Television
Tv clicks off
You most likely have dry joints. If you are not competent with soldering and electronics, you should take it to a qualified repair person. They should not charge you more than £10-15 for repair.
Jan 01, 2008 | Sanyo DS13204 TV
On off problem
removed any magneting material near your tv or any electronic material near you tv specially speakers,, turn it on for 1 min. then turn it off for 5 mins. 4 times..
Jan 01, 2008 | Televison & Video
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Sanyo DS13204 TV Logo
111 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
