2007 ford fusion se 2.3L ,4cylinder. A used motor was installed in my car due to the heads being blown and some broken n bent valves. Everytime i turn on the ac, the car loses power and eventually turns off. the car does work fine w\o the ac on.
    New Friend:
  • 16 Answers
Probably a sign that the A/C compressor is failing and due to this it is putting an abnormally high load on the system. Due to the location of it and the refrigerant recharging and leak checking involved this is not generally considered a DIY repair. Seek a shop qualified to check the car.
Posted on Oct 21, 2013
How to replace valve cover gasket on a 2007 Ford Fusion
Remove bolts securing cover to cylinder head and remove rubber gasket. Clean gasket channel of any oil and install new gasket securely and reinstall cover
May 30, 2015 | Ford Fusion Cars & Trucks
Tip
The compression of an engine is low
Few things to check.It may be due to:
loose spark plug
loose cylinder head bolts
blown head gasket
damaged valves/valves seats
insufficient valve tappet clearance
warped cylinder head
bent valve stems
worn cylinder bore
worn piston rings
broken connecting rod
broken piston
on Dec 19, 2009 | Garden
How to fix my ford ganger 2001 v6 3 o l I have low comprecion cylinder number 2
Well, there are a few causes for low compression....bent valve, broken rings, worn cylinder, broken/ chipped valve, blown head gasket, cracked head, cracked block/ cylinder, broken/ cracked piston......as you can tell, none of which are good and always means going into the engine to repair. A lot of times it is quicker, cheaper, and easier to exchange the engine for either a remanufactured or good salvage yard engine.
Sep 26, 2014 | Cars & Trucks
How would i know if a engine has a bient valve
if it was a bent valve compression would not be the same on all cylinders. you need to go over every thing you did to make sure connections are tight and correct with electrical, vacume, and fuel.
Aug 06, 2014 | 2011 Ford Fusion 2.5
Low comperssion maza 626 after replaced headgasket
Did it have good or fair compression before the repair? Could be poor work or improper part used. More than likely due to timing of the valves now off and this is letting the motor spin with the valves open. Could be damaged head/valves. This is common on interference type motors where the piston and come in contact with the valves. They get bent when the timing belt is broken or improperly replaced and then you have much bigger problems than a faulty head gasket. Check the valves are fully seating. Verify the lash and if way off you likely have bent the valves.
Jun 17, 2014 | Cars & Trucks
2.5l V4. Como sincronizar cadena de tiempo?
Motor Ford 2.3 Lts. 16 V. Sincronizaci?n Timing chain kit ...
? 8:18
https://www.youtube.com/watch?v=QEzqopUjSak
Jun 10, 2013 - Uploaded by Carlos Parra Cort?s
Saludos no se usa un diagrama para sincronizar se tiene que poner ... ... Ford Escape & Fusion 2.3L 2.5L DOHC Engines: Valve Cover Gasket ... COLOCANDO LA CADENA DE TIEMPODE MAZDA 3 FORD ECO ESPORT ...
Sincronizaci?n de cadena de tiempo tracker - YouTube
? 0:13
https://www.youtube.com/watch?v=oFb44LJ9msY
Jun 6, 2014 - Uploaded by tonyeldogor
Puntos de referencia de cadena de tracker. ... 2001 Chevy Tracker V6 2.5L Head Instal and Timing Chain Instal - Duration: 25:45. JunkStar ...
Montaje de cadena de tiempo Zuzuki XL.7 - YouTube
? 3:52
https://www.youtube.com/watch?v=4k73S3dg5mI
Jun 21, 2014 - Uploaded by carmax100pre
Se demuestra solo es montaje de la cadena de tiempo. ... 2001 Chevy Tracker V6 2.5L Head Instal and Timing Chain Instal - Duration: 25:45.
Ford ranger 2.3 motor argentino CADENAS A TIEMPO ...
? 5:03
https://www.youtube.com/watch?v=8dR8mo8Ooy4
Jul 1, 2013 - Uploaded by eduardo soledad valencia
Jan 22, 2013 | Ford Mondeo Cars & Trucks
Ford Focus - 12 years old, broke timing belt. The garage is saying I need a complete new cylinder head. I suspected it was the timing belt and expected several bent valves at worst. My question is...
Here at my repair shop have never had to replace a cylinder head, due to timing belt failure, just replace bent valve's and machine head.
Nov 11, 2010 | 2000 Ford Focus
Ford fusion 2007, blown blower fuse, replaced fuse, works at highest speed only (highest of 4) the other three setings don't work.
hte blower resistor is shot, near the blower motor, have the blower motor checked my guess is that it requiring too much power to run, hence the blown fuse
May 06, 2010 | 2006 Ford Fusion
2007 ford fusion sunroof wont open what would be the cause of this
CHECK FUSE IF OKAY.CHECK TO SEE IF POWER GOING TO SUNROOF MOTOR SWITCH IF YES SUNROOF MOTOR COULD BE FAULTY OR IT NEED ADJUSTMENT.SWITCH COULD BE BAD.IF SWITCH IS GETTING NO POWER FUSE IS GOOD THERE IS A BROKEN WIRE FROM FUSE TO SWITCH.
Feb 22, 2010 | 2007 Ford Fusion I4 SEL Sedan
Where is the oil filter located on a 2006 ford fusion
On the v6 which is the largest motor available on the fusion it is located at the front of the motor facing the cooling fan and radiator. On the 4cylinder it is located also at the front of the motor under plastic cover. take the two 10 bolts of and slide cover off. This filter is a cartridge type remove cap and reinstall cap with a new cartridge and o ring.
Feb 15, 2010 | 2006 Ford Fusion
20 people viewed this question
k24674
jasbo
jasbo
