Xerox d125 with 077-311 code. Can't reset. Whats it?
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Sir 010-398 in my colour xerox machine model no 1632 plese give me solusation whats problem give me answer
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
Feb 26, 2011 | Xerox DocuColor 1632 Laser Printer
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
How to reset the xerox phaser 7500 chip?
I ´m searchingfor the same answer. I have been refilling the toners but now it seems thatthey reach the limits, so the printers is asking me for a new toner. I knowthat you can find from alibaba.com the reset chips. If I have any news I'llposted, please do the same.
Nov 15, 2010 | Xerox Phaser 7750DN Laser Printer
Xerox 5765 enter diagnostics
any 9 code is xerographic. This machine isn't worth fixing if you want me to be truthful. The parts alone will cost you more than enough. Look for DC12 on ebay or something to upgrade.
Sorry, but its the best solution
Jan 08, 2009 | Xerox DocuColor 12 Color Copier
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Jan 05, 2008 | Office Equipment & Supplies
54 people viewed this question
jasbo
jasbo
