Question about Optics
Defective side mounting plate for B-Square Ruger Mini-14 scope mount. I'm pretty sure the side mounting plate I got with my Mini-14 mount is too short. While shooting the rifle without the scope screwed on the side plate fell off the rifle. Needless to say I was not happy. May also explain why we have been unable to get this mount to hold zero! Does B-Square stand behind their products or am I on my own to fix their short comings?
fps353535
  • 99 Answers
SOURCE: Ruger 10/22 Scope problem
This happens will all firearms. what happens when the bullet leaves the bullet is a decieving "rise" of the bullet. The reason for this is the Line of Sight (Scope View), angles down and away from the Line of Departure (Barrel). The bullet actually never rises and is in fact continally falling away from your rifles Line of Departure but because this is higher than the Line of Sight the bullet seems to Rise than fall to the set distance in the scope (i mention set distance and not zero because you can change your Minutes of Angle on your scope to increase and decrease range)
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this is a chart that illustrates what i just said.
now that you understand that you should take a good read into Exterior Ballistics. this is the Mathematics of your fireamrs trajectory ( I say your firearms because your bullet's flight depends on the length of the barel which will vary from gun to gun) this science of shooting will teach you how to understand bullet Grain and Volume relations. understanding the Feet per second of your rounds and how the affects you. teach you about shooting in high pressure and low pressure environments and extremly windy environment.
now there is alot of math to all of this and its hard to find it all on the net and if your not that great at math you can do what i do bc im lazy and im not a sniper im just a hobby kinda guy. '
Sierra Infinity V 6 Ballistics Software. I dl'd mine off the net you might have to buy it depending on how resourceful you are. it is well worth the buy. You can punch in the daily variables (Barometric Pressure, Temp, Humidity, and Altitude) (of couse with your bullet as well) and it will give you a "Cheat Sheet" for those conditions stating Windage and Elevation adjustments per decided incriment (50 yrds is standard) then you take that to the range and (bring a laptop if you got it and arent embarrased (som1 might even help you tune in the variables) hope this helps if not ill check back in a bit to see how you did
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Posted on Apr 17, 2009
miket756
  • 2702 Answers
SOURCE: marlin .308 with leopold scope. I've moved the
marlin rifles have a right hand twist in them,, they all shoot to the right,,,if you pack out the scope mount with a strip of old 35mm film on the right hand side of the scope body and reclamp the scope you should have the cross hair more to the right side
Posted on Nov 17, 2009
fawkwindows
  • 96 Answers
SOURCE: My wife has a Ruger Mini-14 patrol rifle with the
If your wife wants to use it for defense and, etc have her cowitness the optic 4moa sight with what Solution #1 suggested, instead of the normal position of the optic. Co-witnessing optics is better suited for quicker reactions, snapshots with the pekiti take off "advanced version of getting off the x"
Posted on Dec 13, 2009
  • 243 Answers
SOURCE: keep having to resight scope
Sounds like they are right. The cross hair adjustment mechanism may be defective. I'd call bushnell and see what they can do for you.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Posted on May 31, 2010
Finding manufacture date
If we are talking about a Ruger Mini 14 that number is probably 182-92513. That serial number was manufactured in 1981. If you need a more specific date you will need to contact Ruger.
http://ruger.com/footer/contact.html
Aug 08, 2014 | Ruger Mini 14 Ranch/Mini 14 Tactical 223...
I bouht a ncstar scope mount I cant figeur out on how to mount it.
Is it for a plain jane mini-14 or a Ranch Rifle. the mount and mounting process is different.
May 31, 2010 | NcStar Scope Mount RUGER MINI14 / MINI30...
The plate that the mount screws to is loose how do i tighten it?
You mean the one you have pictured there? It has the big thumb wheel on it? It won't tighten up? Is it stripped? Or is the receiver stripped out? You could replace that big screw with a bolt, you would lose your quick detach, Or if the receiver is stripped, you'll have to get it tapped out, and get the new bolt anyway, going up one size. and using a fine thread. It can be a screw, with a slot head or an allen head. Hope this helps.
Feb 26, 2010 | Weaver Ruger Mini 14 Rifle Elevated Scope...
3-9x50 BSA Deerhunter Rifle Scope.
What that means is they are not mounted correctly. The scope mounts should be square with your rifle when fitted, when the scope is placed into the mounts, it should be turned to be square with the rifle.
Firstly, make sure you do not "cant" when you shoot. That is hold the rifle at an angle instead of vertical. Once you are sure that is OK, then put it into a vice using blanket or some other soft material to protect the stock. Get the rifle perfectly square using a spirit level. There should be a flat spot on the top of the action that you can use. Once this is achieved, you loosen off the scope mounts and square the scope up to your satisfaction. Once done, tighten the mounts up and then remove from the vice.
Feb 10, 2010 | Optics
Ruger 22 pistol, Serial number 20476. Year made and value?
For the information you require you will need to take it to a gunsmith, or contact Ruger themselves.
http://www.ruger.com/index.html?r=firearms
Feb 03, 2010 | Weaver Ruger Mini 14 Rifle Elevated Scope...
Sep 15, 2009 | Optics
Apr 07, 2009 | Weaver Optics
Optics Logo
32 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
