Question about Sewing Machines
I was given a dial n sew model 752 sewing machine and it will not sew (make stitches) the tread does not sew into the material. Can you help me?
    Champion:
  • 208 Answers
Make sure you have the needle in the correct way round and that it is a new one and nor blunt or bent, failing that your machine may need retiming
Posted on Oct 25, 2013
4 Suggested Answers
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
Can this machine sew synthetic materials?
all machines can sew synthetic materials
go google and type in--- user manual for ( make and model ) sewing machine --- and down load a pdf version
Dec 16, 2015 | Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
How do I just the tension on my Singer 621B
There is a nob for tension. Put scrap material under foot to sew. Dial tension run a couple of stitches that would be tight ,not good turn to right that loosens stitch. Keep trying till problem solved. Lots of patients .
May 20, 2014 | Singer 2263 Mechanical Sewing Machine
Dial n sew 752 have no manual how to thread and get started
Unfortunately, i cannot locate any free copies but here is an inexpensive one.
http://ifixmachines.com/Deluxe-Zig-Zag-Model-65-752/View-all-products.html
It IS the correct machine manual.
Please rate Fixya
Thanks
Mar 28, 2011 | Sewing Machines
I have a Vogue Stitch sewing machine made by Speigel. Model 752-805. I need a manual to know how to thread it.
I have a manual for the White 8058 - it's really 805B. I would be happy to email it to you.
Feb 08, 2011 | Sewing Machines
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
