Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
Replace mower deck belt - John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
    Problem Solver:
  • 16 Answers
Take the old one off, measure it and round down to the next size which you can purchase from a dealer, online, or at a general small equipment supplier. There is no trick to getting it off and on, merely a tensioning pulley on a spring that you push on to create enough slack to get it off a pulley.
Posted on Oct 21, 2013
2 Suggested Answers
roadtech7
  • 293 Answers
SOURCE: need to know how to adjust deck belt on a 54
I would need the model # of the deck and tractor, but all newer mowers use a spring to maintain constant belt tension. I can get you a diagram if you need one.
Posted on Dec 03, 2011
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need diagram to replace belt on manual trans john deere 265
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
Apr 13, 2011 | John Deere Garden
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Every time I lower my mower board my mower stops or slows down. I just replaced the mandrel and also the belt. When my mower board is raised up all the way the mower works good.
Lower the deck without it running and see if anything is making contact with the mower belt that shouldn't be. Sure sounds to me like you have the belt in a bind when you lower the deck, possibly by not routing the belt in the correct position when you replaced the belt.
Aug 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
152 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
