Question about Panasonic KX-T7731 Corded Phone
Phone makes no ringing sound - Panasonic KX-T7731 Corded Phone
  • 45 Answers
Does the sp-phone work? if not, then you need to change
the speaker unit.
also check the ringer switch on the right side.
Posted on Oct 29, 2013
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
The phone won't ring. How do I make it ring? I have gone to settings, sounds, ringer and alerts. When I click on that, the phone makes a ringing sound, but when calls come in, it is silent. Please...
Have you checked the switch on the top left of the phone?
That's the mute switch. Flip it in the Up position and that should fix your problem
If the phones ringing when you test the ringer in the settings, the ringer works. It's probably just muted..
I hope that helps...
Thank you
Aug 25, 2011 | Apple iPhone Smartphone
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
We cannot receive or send a fax. If I dial our fax number it rings as a normal phone and not the sound that a fax number makes. The machine is only a few months old.
Not sure how a fax machine is supposed to sound when it rings, before the fax answers it will sound exactly the same on the phone as dialing a regular phone number. If you are using distinct ring tone service where the fax line is supposed to double ring and it is not then it is possible that your phone provider has problems. Are you able to make a regular voice call on the phone line that the fax is supposed to use? If no, then it is definetly the line not the machine.
Apr 18, 2011 | Samsung CLX-3160 All-In-One Laser Printer
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My phone is ringing but cannot hear the sound only blinging the light. So how can i return back the ring sound?
Only 3 things make it not ring, there's a switch for the ringer on the left side of the phone, it needs to be programmed to ring in the 40x's, or the ringer is defective. If it rings on the intercom (with the AUTO ANS) turned off, it must be programming.
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
Phone will not ring, only vibrates even tho I use the side volumn control to choose ring volume one, or two, or three or four, or five. None work to make it ring
Hello
The reason your phone isnt ringing out is because the speaker of your phone is faulty.
The sounds made by your phone(including the ringing tone) is heard through the speaker and once it is faulty,you will not hear any sound coming from your phone.
The only solution is to have your speaker replaced.
Cheers
Mar 27, 2010 | Samsung SCH-u340 Cellular Phone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Ringing sound is less
go to the phone settings maybe your phone are muted make it unmute and did you try to replace speaker, maybe one of his wire are desconnected
Jul 04, 2009 | Nokia E63 Cell Phone
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
Jul 28, 2007 | Motorola Mobility RAZR V3
Panasonic KX-T7731 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
