Seagate model ST300000U2 external hard drive start button no longer works. If I hold it in it does not flash blue but I can hear the drive start until I let go of button. What should I do to repair this?
JLPicard
  • 14 Answers
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
Posted on Nov 17, 2007
brianrow
SOURCE: external hard drive not registering with the computer
WOW!! I was out of options and was desperate to find a fix for my External. So i took it out of its case and looked it over like the other solution states. I decided to plug it in while it ws out of its case, and i began squeezing it among other things. Finally when i pushed on the area on the bottom where you can see the disk is located, it grinded for a second. After that my drive started to work again!!!!!!! Unreal i thought i ws gonna lose everything i had. Id recommend trying this as a last resort and it dont take alot of pressure, just press on it until you feel the disk vibrate.
Hope this helps someone else as well.
Posted on Oct 08, 2008
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
  • 28 Answers
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Posted on Sep 14, 2009
Crankstart
  • 696 Answers
SOURCE: seagate external hard drive is flashing blue light
Sounds like you have either bad voltage from your power adapter or a failed enclosure.
First thing to do is check the ac adapter your using, find the output Voltage, should be between 5-16V and the output Amperage, should be between .25A and 5A depending on the type of seagate enclosure you have.
Now look at the stickers on the outside of the drive enclosure to verify that it uses the same voltage and amperage. If it doesn't you're using the wrong adapter(easy mistake after a move). If it's the correct adapter then you may have had a failure in the enclosure.
The next thing to try is to take the drive to your local PC shop and ask the technicians there to transfer the hard drive inside it into a new enclosure for testing. If this works buy the new enclosure and you're on the way. If this also fails, something has failed in the drive itself and you will need the help of a pro. Have the technicians either return it to the original enclosure or pack it in a static free bag.
Now you have a couple options. I can refer you into one of several professional facilities depending on your needs. The most common one I use is www.armor-it.com They are the least expensive on average but average 4-5 weeks for non rush orders. If you need a faster turnaround and don't mind spending a few extra bucks, reply back and including your Country, City and State and I will refer you into an appropriate facility near you.
Crankstart
Posted on Jan 08, 2010
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
Seagate blue light flashing
Just a thought.......see if it's got a reset switch. It might be a TINY little thing
Jan 02, 2014 | Seagate Expansion 1 TB USB 2.0 Portable...
Can a Seagate External Hard Drive be reformatted?
Yes you can.
Insert the external hard drive into the USB port click on My Computer then right click on the external hard drive and select Format.
Apr 01, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent keeps dropping disconnecting
Seagate manufactures both internal and external hard drives, and their sleep modes can be managed in different ways. The hard drive is one of the top energy consumers among computer-hardware components, and Windows operating systems support options to reduce power consumption. Internal hard drives are typically turned off and stop spinning ("sleep" mode) after a certain period of system inactivity. However, the system usually takes longer to come back when the hard drive's sleep mode is activated. Furthermore, turning off hard drives may result in failure of some constantly running applications.
Windows includes options to turn off sleep modes for internal hard drives, and external hard drives can be managed using a utility program.
Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and then "Systems and Maintenance." b> Click on "Power Options." Open "Change plan settings" under your current power plan. Note "Radio button" is selected for the current plan. Click "Change advanced power settings." Expand the entry "hard drive" by clicking on the "+" sign. Click on "+" to expand the entry "Turn off hard disk after." Select "Never" for this option and click "OK." b> In Windows XP Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and switch to the "Category" view on the left panel. Then click on "Performance and Maintenance." Click on "Performance and Maintenance" and open "Power Options." The select the tab "Power Schemes." Using drop-down list, set the option "Never" for "Turn off hard drives." Click "OK." b> Using "NoSleepHD" for External Hard Drives b> Click on the "NoSleepHD program" link in Resources. Click "I Agree" and save the program (as a zip file) on your computer. Open a folder where you have saved the file using Windows Explorer. Right-click on the zip file and select "Extract All." Then click "Extract" to get the program file "NoSleepHD v1.0.exe." Double-click on the program (.exe) file to execute NoSleepHD. Click "Select External Hard Drive" in the Program menu and choose your Seagate external hard drive. Choose "10 minutes" under the option "Write File every" and click "Start NoSleep Mode." The program will write an empty string every 10 minutes to the Seagate hard drive and prevent it from going into sleep mode. Hope this helps.
b>
Dec 29, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi. I have a Seagate FC remote hard drive. The power light has started flashing and the drive is no longer recognised or readable by my computer. Do you have any suggestions?
If you don't hear any other weird sounds coming from the drive, you need to replace the logic board on the hard drive. Find an identical hard drive part on eBay and replace the logic board on the hard drive and everything will be working 100%.
May 06, 2011 | Seagate Computers & Internet
Seagate 9SF2A4-500 external hard drive on Windows 98
Windows 98 will not run a drive that large, so that is your problem. You will need to connect it to a newer system, and break it down into small drives by setting up different partitions. Perhaps it will see it then. Also, most manufacturers are no longer supporting Windows 98. You really need to just upgrade your system to a newer OS.
Feb 13, 2010 | Computers & Internet
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My Acomdata (500gb?) external hard drive isn't working
Place it onto another computer, if you can see it and access it then plug it into a differant USB port on your computer.
Jan 14, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
External Seagate Hard Drive making clicking noise
Did you plug it into a different USB port?
The click noise (at least from the usb hdds that i have had) is due from it being underpowered. So if you plugge it into a different USB, move it back to the other.
Nov 25, 2008 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
