Home | GE | WJSR2070B Top Load Washer | Dumps water on floor
GE WJSR2070B Top Load Washer
Problem for GE WJSR2070B Top Load Washer
By beezer5410 on Apr 26, 2009
After 1 complete load with no problems, the washer will immediately dump out the full capacity of water of the first rinse cycle of the second load on my floor. All my hose connections are fine along with my drainage to the septic field. Where the hell is the water coming from and why? And how do I fix this?
Solution #1
posted on May 20, 2009
Not Rated)
justaskjoe
Rank: Guru  GE Expert
Rating: 85%, 1848 votes
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Comments:
May 20, 2009
- good luck with it. get back if i can be of further assistance
Was this helpful?
Yes
No
Popular Solutions for GE WJSR2070B Top Load Washer
Questions and Unsolved Problems for GE WJSR2070B Top Load Washer
Do you recommend GE WJSR2070B Top Load Washer?
Answer
Answer
Wash doesn't seem to drain all the way, some of the time. I need to re-spin and re-rinse alot.
Answer
how to remove the front panel for a GE upright washing machine? Model: WJSR2070b. I have a leak from... (More)
Answer
Good Morning: my Ge washing machine won't spin
Answer
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WJSR2070B Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14047
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
