Question about Karcher 2500 PSI Pressure Washer
This is a 2002 ford focus 18 tdci the problem is the heater plug light comes on intermittently when it does the engine looses all revs seems to go in to limp mode but if u turn the ignition off and back on straight away it clears up for a short time this does not happen when the engine is under pressure only when the engine is in idle at traffic lights or has reached a steady speed as in 30-40 mph or at motorway speeds all help great fully received thanks
3 Suggested Answers
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Posted on Jan 08, 2009
  • 174 Answers
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
Ford focus 1.6 tdci on a 61 plate losing coolant when under load
Probably a pin hole leak some where in a rubber type pipe, hose clips may need tightening or your radiator may have been damaged by a stone coming through the grill. You could try getting some one to sit in car and keep revs up on engine until you can see where any steam is coming from, beware steam is very hot. If you find the leak let engine fully cool down before starting any work.
Aug 23, 2016 | Ford Cars & Trucks
Ford focus tdci problems
hi i have a ford focus 18 tdci 2009 and the other day the car lost all power eg electric i taken the battery off the car and charge it over nite i put the battery on the car and i am gettin a warning light saying transmission failure plz can some body help me thankz
Jan 02, 2014 | Cars & Trucks
Ford focus tdci not starting and white smoke coming out of the exhaust
It is a clear case of the glow plugs malfunction. It had happened with my neighbor who tried to start his diesel focus one day.
Even jump starting with another battery didn't solve the starting problem.
You could also check the EGR valve for damages and if you want to save a couple of bucks, then go in for used parts for the focus from Good used Focus Stuff
Mar 29, 2013 | 2001 Ford Focus
Ford focus 1.6 tdci engine management light has come on water temp crept up slowly but dropped when heater switched on any ideas?
Hi,i had similar problem,the fan wasn't working.When i turned heater on hot it released the heat from the engine & temperature went back down.Turned out my fan relay fuse had blown.$5 fixed the problem.Hope this helps.
Feb 14, 2011 | 2005 Ford Focus
Ford mondeo ghia x tdci 2002 power problem
split intercooler hose, happened to mine do you hear a sucking noise when accelerating? new hose costs about 40 quid main dealer only
Jul 08, 2010 | 2004 Ford GT
I have a problem on my mondeo st tdci withthe
hi check your coil first if this faulty it can cause all these problems please rate this answer good luck
Nov 19, 2009 | 2005 Ford GT
Glow plug indicator light
Hi, if the egnine start alright. then it will be the LED or just a blub need replacing.
Jul 21, 2009 | 2002 Ford SVT Focus
Power loss with Focus TDCI 05, Turbo Problem?
Fucus 2005 tdci ESP light comes on then dont want ref over 3000rpms.
Apr 22, 2009 | 2005 Ford Focus
Will a 2003 mondeo tdci engine fit into a 2002 mondeo tdci
They should be. The SVT Models stay Very Consistent on the Motors.
Jan 21, 2009 | 2002 Ford SVT Focus
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
