Question about EliteGroup NFORCE4M-A Motherboard
No picture on monitor and regular beep from PC Case
Hi I recently had a system crash where my old motherboard literally fell apart. I decided it was time to try building my own, using a combination of cannibalised parts from the old system and new components. Connected to the motherboard on first boot attempt were; 2 SATA hard drives, 1 with XP installed, the other re-formatted 1 DVD RW drive on primary IDE 1 3.5' floppy AMD 6000+ Processor (using packaged heatsink and fan) - This was a returned, previously opened product and may be part of the problem 1Gb DDR2 PC2-4300 533MHz RAM - Again, returned goods 2 80mm case fans ATI Radeon 800 PCI Express 128Mb graphics card (originally bundled with previous PC) First problem encountered is a lack of signal to the monitor. I suspect this may be due to an incompatibility between mobo and card but it's hard to tell with no picture! Meanwhile, a bleep from the case speaker is repeated at around 3 second intervals. Hard drive seems to be being accessed but, again, hard to tell without picture. Processor fan appears to be spinning normally and, as far as I can tell, heatsink and fan are installed properly (however, I did not apply any thermal grease before installing heatsink as install instructions advised a thermal layer already applied.) Have tried various combinations of the above list, and also tried using a PATA hard drive on the primary IDE, but all with identical results. Also tried boot with no graphics card at all installed - same result. I have also tried swapping the slot in which the RAM is installed. Again, no difference. There are no obstructions to any of the moving parts, all fans are functioning normally and, as far as I can tell with no monitor, the hard drives are running OK. The first question is obviously is the ATI Radeon card simply incompatible with the motherboard? If so, is the graphic card incompatibility / unavailability likely to be the reason for the case beep? And can anyone recommend a cheap, compatible replacement card? If not, can anyone suggest anything I may have overlooked? Thanks in advance for any assistance anyone is able to offer. Cheers! Sharaz
    Novelist:
  • 231 Answers
Hi, in my workshop I have struck similar problems and have almost always found it to be the RAM that is at fault, try a completely diferent RAM stick and see what happens. Regards mistyman
Posted on Sep 28, 2007
SOURCE:
Hi - recently I've been getting a no signal message on my monitor - system is still runnung but no video. I have checked cables - all are OK - The computer is a Gateway DX4300
Three major components usually is causing this kind of problem. One is the memory card. Two the video card . and lastly worst is the motherboard. Check and clean your memory card first then put it back to its place of slot. Start your computer. If you hear one beep but still no pictures, the problem lies in your video card. If there's still no beep sound and picture, and you think your memory card is good, try to clean your video card, then start your computer. If there is still no picture, and you think your video card is good, then you have a problem with your motherboard. Indication that your cpu is working were, beeping sounds, lead lights blinking or changing sequence is present. If it is present, your monitor has a defect an needs to be replaced.But if none of this is present, we have a motherboard problem.
Sep 04, 2011 | Gateway DX4300-03 Desktop PC
Emachines 5210 wont start up - monitor goes to power saving mode - no beeps but all fans & mobo powere active
Sounds like you have some type of hardware failure. If you are comfortable taking apart the system, start by removing the memory. If this system beeps then you know that your motherboard is still OK. But right now I am thinking that you may have a faulty motherboard.
Jul 06, 2011 | E-Machines eMachines Desktop PC
I have a hp m820n and it crashes or won't start and has a long beep then a short beep i am wanting to know if that is the motherboard that is crashed
Hi.
This could be one of 2 problems.
1, there is a system memory problem. Open the case and carefully clean the inside of dust. Next, remove the memory modules and clean the slots with a soft, dry paintbrush, also clean the brass contacts that run all the way down one side of the memory.
The memory modules look like this >>>>>
2, there could also be a problem with the graphics (video) card. Take it out and clean the contacts and the slots.
Hope this helps.
Regards.
May 17, 2011 | HP PAVILION M8200N PC Desktop
Can your Hardware (network/monitor) cause your computer to freeze, crash/restart on its own? The reason I ask is the I'm trying to fix a computer that when use online it seems to freeze/crash at first I...
Of course, but it should be a major failure that would make them practically unusable - not your case. You most likely use IE and it's a POS that crashes with regularity when it's encountering a more demanding site. Just use another browser and your problem  will go away. Don't forget to scan your pc for malware before.
Jul 23, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Came home and my computer turns on but screen does not come on what do I do?
Hi alexisglrz, the first thing is to connect an external monitor and then press "FN" (keep it pressed) and I believe it's F4 or F2 (it has like a monitor or lcd picture) twice!. In case you don't see any video you have to take it to a repair shop because it could be the motherboard. If you hear beeps it could mean the memory is either loose or faulty. You can check by removing the screws on the bottom. But replacing the motherboard it's just complicated to the regular user. I hope this helps. Dont forget to rate. Thank you.
Apr 28, 2010 | HP Pavilion dv6000z Notebook
Finding it hard to put leads back on to motherboard to boot up
From the motherboard number you gave, I think it's made by ECS. Take a look at the picture on this page at the ECS site and see if it looks like your board:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=530&DetailName=Feature&MenuID=52&LanID=0
If it's the one you have, you can download the manual just by clicking the link below the picture. You can also get any other information and driver updates that you might need.
Please take a moment to give this solution a good rating if it's been helpful.
Mar 02, 2009 | Computers & Internet
No video output on Intel D915GEVL motherboard with Intel GMA900
hi there
if you would power down the computer and the monitor and unplug the cord going to the pc from the monitor and the power cord for the computer,,, now open up the case and find the powersupply cable going to the motherboard and unplug it now preess the computers on button than the reset button .. this will discharge any esd than wait 3 min and plug it back in than connect the monitor to the pc and plug in the power cord for the pc and monitor and turn on the monitor and you should get a messzage that the monitor is working now turn on the computer and see if it works let me know how this works ok
best regards mike
Feb 22, 2009 | Intel D915GEVL Motherboard
Motherboard don't allow to run monitor
those wires .. are the intrusion detect switch .. they are not your issue .. but if they are connected somewhere and your not 100% confident .. I'd disconnect it ..
on the system they is a lable w/ a "Type" number and "Model" number .. what are those ..
Do you have a PCI Video Adapter .. or is in on the MB .. or both ?
Are there 2 HD15 connectors ..
does the system beep at you when you power on?
if you have both a PCI card and an Embedded graphics controller .. remove the PCI .. connect your monitor to the embedded and try it
Jan 08, 2009 | Abit BD7II-RAID Motherboard
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
Open Questions:
ZONEALARM TeCH sUPPort pHoNe ~\18OO/8\O/3\1O69/~ numbeR activations Usa ZONEALARM USA phone number is ranked #2 out of 2 because 7,728 ZONEALARM USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he ZONEALARM USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, ZONEALARM USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ZONEALARM USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ZONEALARM USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ZONEALARM USA Calling ZONEALARM USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ZONEALARM USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ZONEALARM USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ZONEALARM USA's phone numbers against each other. Contacting ZONEALARM USA in General While I8OO8O31O69 is ZONEALARM USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ZONEALARM USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ZONEALARM USA.
Oct 18, 2019 | Best Computers & Internet
See all EliteGroup NFORCE4M-A Motherboard Questions
EliteGroup NFORCE4M-A Motherboard Logo
107 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
