Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
Uf 9000 ip address
How do I change the IP address on the machine itself? I've looked at every function in this machine and nowhere did I see the IP address to be able to change it.
Just wondering if you've found a solution. I'm trying to do the same thing on our uf-9000. Any help would be appreciated.
Panasonic technical support is not good.
Posted on Oct 22, 2013
  • Renee Batey
    Renee Batey Nov 05, 2013
    I had to reset the Panasonic back to factory defaults. Then I installed the driver and communications utility which I downloaded from Panasonic's website. After resetting the machine, our DHCP assigned it a new IP address and the utility was able to find it on our network. Good luck!
Loading software for network asking for IP address
Usually you can run a report on the printer that will show you the IP address it is using.
Mar 26, 2014 | Panasonic UF-8200 Panafax Panafax UF-8200...
How can I find the uf 9000 ip address from the printer controls? When I try to install the driver, it does not find the printer on our network and I don't know what IP address was assigned to it through...
If you are the network supervisor you know or should be able to know the IP address of every device. If you are not the supervisor why would try to install anything on the network? You should talk to the IT geek who supervises the network.
Oct 22, 2013 | Panasonic Panafax UF-9000 All-In-One Laser...
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
How do I change my WD5000G032-001 external hard drive's IP address?
Very few external disk-drives _have_ an IP-address (the Apple Time-Machine is the exception). For those drives that do,
they obtain their IP-address automatically, by sending a 'request' out through their network-connection. A DHCP ('Dynamic Host Configuration Protocol') server on the network sends an IP-address to it. Most 'home' routers (wired or wireless) include the DHCP-server functionality.
So, the only way to change the IP-address is to configure the DHCP-server to always assign the desired IP-address whenever that specific device sends a 'request' for an IP-address.
Oct 06, 2010 | Western Digital 500GB My Book World...
I ve adsl device for wireless sometime it works n sometime i ve to plug in cable because wireless function not works
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 10, 2009 | Dell (430-3572) Wireless Adapter
How do you set the IP address for network use?
Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. eg - IP address = 192.198.0.1 & Subnet mask = 255.255.255.0.
Jun 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Panasonic uf-9000
Function
71
set
keep pressing set until you get to ip address
key in with the keyboard
Mar 09, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
User name an password required
There is none. Try the action below:
press
function
7
monitor key slowly 4 times
6
Scroll down to password clear
set
stop
If that doesn't work, choose SHIPMENT SET
set
wait for machine to initialize
Feb 24, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Setting up scanning
turn dhcp off
in copy mode
press function-1-start- up arrow "show say key opp mode" - put 000 -start- then enter 22 start -press 1 for invalid- hit start. then stop stop
Dec 04, 2008 | Panasonic Panafax UF-9000 All-In-One Laser...
Print jobs are not getting queued.
This is late but most likely the IP address is set to DHCP or auto and the printer is changing the IP address.
You need to set it to manual, and set the IP address static.
Those machines will change the IP address by itself.
Sometime even when you have set it manually it will change back to auto.
Feb 19, 2007 | Xerox Phaser 7400DN Laser Printer
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
110 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
