Question about Sewing Machines
Pfaff tipmatic 6122 pdf
Feed dogs stuck in up position, flywheel will not turn. can't detect thread or other debris
  • 92 Answers
Sounds like the machine is jammed somewhere...not sure of this solution, probably thread in the hook though
Posted on Oct 21, 2013
Testimonial: "Thanks. Now have the needle moving up and down, flywheel moving, feed dogs working but with quite a bit of growling noise. Bobbin race does not move. Thread is not picked up. Still can see no thread or debris to remove. This all started with a terrible thread snarl in the bobbin area. Is there some way to gain access to this area to look?"
2 Suggested Answers
SOURCE: bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Posted on Jul 13, 2008
Pfaff tipmatic button hole maker will not move fabric along gets stuck midway
I believe your machine is an older mechanical machine. If so, how long since it has been serviced--cleaned and thoroughly oiled? These old machines need TLC to keep running. I prefer using liquid Tri-Flow Synthetic Lube from the hardware store. Hand rotate the handwheel and apply one or two drops every place where metal rubs on metal. Avoid plastic, rubber, or leather. In your case, the feed dogs may be seized due to old oil that has dried, but it's likely that is happening elsewhere as well.
Apr 15, 2018 | PfaFF Sewing Machines
Given Pfaff 297-1 sewing machine for charity work everthing seems to be right but it does not feed - the feedogs seem to be too low. It's sewing steadily on the spot.
Could be the feed dogs are lowered to do darning. Here's a manual:
PFAFF 294 Instruction Book Page 11
See if the A/B switch makes any difference in the feed dogs.
Sometimes these old machines haven't been oiled like they should and it's possible the feed dogs are stuck in the lowered position. Also, if it was used a lot the feed dogs get worn and no longer work like they should.
Jul 16, 2017 | PfaFF Sewing Machines
How to remove thread that has wound itself around the back of the bobbin case on a Pfaff tipmatic 1035. Is it possible to remove the top plate to get access?
Remove the bobbin case. If the machine has a free-arm cover, it should be removed also. On most older machines, there are multiple needle plates (zig-zag or straight-stitch) available so they are removable & exchangeable, but for your machine, you'd have to verify. You'll have to carefully remove the threads by cutting with a tiny pair of scissors and pulling the threads using needle-nose pliers or tweezers. If you are unable to remove all the threads, you may need to take it for service.
PFAFF Tipmatic 1014 Instruction Book Page 11
PFAFF Tipmatic 1035 Manuals
Pfaff Tipmatic 1035 Owner Manual Page 2
Dec 20, 2016 | Sewing Machines
My white machine want feed material it sounds like it is running fine and wheel is turning correctly what is the problem?
check to see if the feed dogs are dropped(darning mode), or lift the needleplate and clean out lint or debris stuck in feed dogs. when the needle is in the highest position the feed dogs should be about 1mm above the needle plate.
Dec 16, 2016 | Sewing Machines
The presser foot on my Pfaff Tipmatic 6122 will not stay down, so the fabric will not feed.
It sounds like the pressed bar is sticking and will not push down completely and is difficult to lift. I have come across them many times on the older pfaffs. Unfortunately that is not sometime that can be fixed at home. It is caused by the lube going bad inside the pressed bar that lubbricates the spring that is inside the pressed bar. Find a pfaff dealer that knows about older pfaffs and they should be able to help.
Nov 15, 2016 | PfaFF Sewing Machines
Fabric not moving
You probably lowered the feed dogs; the 'button' is oblong shaped, and to the right of the bobbin case. I have had several Pfaff machines, and still sew with one, so email me if you still have a question. Sheila sheeleigh@yahoo.com
Apr 05, 2014 | PfaFF Sewing Machines
Pfaff quilt expression 4 0
Not sure what the problem is but you might try this:
Remove the top thread completely from the machine.
Make sure the machine is cleaned under the needle plate, the hook/bobbin area, the feed dogs, etc.
If your manual instructs oiling, do so as described.
Confirm that the feed dogs are in the raised position.
ALWAYS RAISE the presser foot then rethread the top thread from the beginning.
Verify the thread path is correct.
Confirm the needle is installed correctly (does the flat part face the right direction?). Is it the right needle for your machine.
Set the top tension to the midway point.
Check that the stitch length is set to at least #2.
Re-test your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Some machines have a presser foot pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and the feed dogs. You may need to increase this pressure.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjUwYDwuKjVAhULwFQKHRLIA1YQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AFQjCNFFR0YpgCUh8R92wNbPzlJpuzWVNw
Jul 26, 2017 | Sewing Machines
Sewing Machines Logo
166 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
