Question about Bumblebee BT-B11 Bluetooth Headset Black
How do I reset a Bumblebee BT-X1 Bluetooth headset?
I need the pass code to pair with nokia n70
I see you want your BT headset to be connected to your Nokia N70.
The pass code will be 0000 to be able to get the BT headset connected, Also make sure the phone Bluetooth settings is set to be discoverable in the Phone BT settings OK.
Have nice day.
Jul 25, 2011 | Plantronics Explorer 230 Bluetooth Headset
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
May 05, 2011 | Genius BT-03A Bluetooth Headset
What is the BT-10K Bluetooth passkey
Well the default pass key for most of the headset's is 0000 so you can try this .........
Good Luck!!
Jun 08, 2010 | Just Wireless Bluetooth Headset Wireless...
Bluetooth setup
You need to pair your phone with your bluetooth headset.
  1. Turn on your phone's bluetooth and search for bluetooth devices.
  2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Nov 11, 2009 | Radio Communications
I need to put my samsung bluetooth (wep 301) in discoverable mode
Whenever you connect your bluetooth (BT) headset to a BT device:
  1. Set the BT device to search for other devices.
  2. While the BT device is searching and the BT headset is off, press and hold the call/end button on the BT headset until it's light is constantly lit and the BT device finds it.
  3. Enter passkey 0000 when asked.
Nov 07, 2009 | Samsung WEP301 Bluetooth Headset
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Sx66 cant hear people and they cant hear me
i encountered this problem after i started using a bluetooth headset. when the headset is not in use (not turned on, not even with me), sometimes there is no sound from the speaker, and the other party cannot hear me. meanwhile, the call timer is clicking away indicating the call connected. it seemed there was some issue in the bluetooth stack, and the phone thought it should be communicating with the BT device rather than it's onboard speaker/mic. to resolve, i disconnect the call, go to the main screen; in the bottom right corner, use the bluetooth manager icon to turn BT On then Off again. this resets the phone's speaker/mic usage, and calls can be made like normal. i hope this helps you.
Jan 07, 2008 | Siemens SX66
Bluetooth headset won't play music
hello,
All the bluetooth wireless headset are only capable of making/receiving voice calls.
Y?
its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
BT 1.2, Version playing music through a BT headset while music is playing on laptops.
and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
hope this little information helps.
TY
Nov 29, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Bumblebee BT-B11 Bluetooth Headset Black Logo
71 people viewed this question
Top Bumblebee Radio Communications Experts
eradiostore
eradiostore
Are you a Bumblebee Radio Communication Expert? Answer questions, earn points and help others
