Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
When I turn gas to furnace pilot light goes out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Now getting enough oxygen. To much fuel but it can not breathe try adjusting pilot nozzle.
Posted on Nov 04, 2013
How do I light my gas furnace
light my gas furnace Marbillw, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to turn your furnace pilot light on
How to Light Furnace Pilot Light HowStuffWorks
http://www.centralhtg.com/blog/how-to-light-a-furnace
How to Light Pilot Light
Jun 08, 2016 | Heating & Cooling
I replaced the thermocouple and I can not get furnace to light.
turn to pilot to light pilot
hold and wait should be instructions on control
turn to on position if pilot goes out start again
Nov 02, 2015 | Heating & Cooling
If the pilot go out on a furnace would gas continue to flow to the pilot , or would it shut off with in a few seconds
The pilot flame heats a thermocouple, so if the pilot goes out, the thermocouple cools and shuts off the gas. It can take anywhere from 20 seconds to 2 minutes for it to shut off. You should hear an audible click when it happens.
Sep 14, 2014 | Heating & Cooling
Where is the furnace breaker
Is the pilot light lit? There should be a valve that turns the gas off at the furnace itself. This valve is for the pilot lite There is no breaker of sorts but rather a sparker that lights the furnace. If the furnace does not light there is a small 12 volt valve that shuts off the gas to the furnace but not to the pilot light. Also make sure your 12 volt system is connected and operating. It wont work without it as it operates off that system not 120V. The same goes for refrigerators, the will not function with the 12v system disconnected
Apr 13, 2014 | Keystone 2013 Hideout 32FLTS
Lighting the furnace pilot light. when I turn the gas to the on position the pilot light goes out
Well if you held the pilot knob down for 1 to 2 minutes before you turned it to on and it went out your thermocoupler is no good and needs replaced
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
Furnace Pilot Light Won't Stay Lit
Here is something similar that happened to me. I went through the same steps you went through and upon closer inspection, I found a spider had made a web inside the supply line only letting a small trickle of gas through. Have you verified there is nothing blocking the line?
Oct 02, 2012 | Heating & Cooling
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
How do I light the pilot on my InterTherm MGBB 070 furnace? I have tried holding in the pilot switch but have had no success in getting the pilot lit.
Just to make sure you are trying to light the pilot, from the gas valve follow the small diameter pipe (1/8") to the pilot assembly. Where you should be placing your flame is above that point. Now with the gas valve knob turned to the Pilot marking, depress the know into the gas valve. Light the pilot. Check to see if it is lit and remain holding the knob in for 30 to 45 seconds. If the flame goes out as soon as you let out the knob, you will need to replace the thermocouple.
Oct 11, 2009 | Heating & Cooling
Pilot ligting instructions
many of the newer furnaces don't have a standing pilot. look to see if you have a gas valve with a knob on top that says off pilot and on. look to see if a tube the size of a pencil comes out of the valve and goes down by one of the burners, look to see if there is a little gold piece of metal tubing protruding down to the opening of the larger tube . that is where you place the match. i prefer to use a grill lighter. safer and positive flame. turn knob to off wait 5 minutes for any gas to disipate. be sure your incoming gas valves are all open . usually at the meter and one at the furnace. usually the handle is in line with the pipe when open. from the off position, turn the knob on the furnace gas valve to pilot position and push down on it as you turn. this lets gas flow to the pilot tube by the burner where you have you flame starter lit and waiting. once pilot lights hold down on button for 3 minutes or less. longer is better to be sure the thermocouple senses flame . then gently release the downward pressure and the pilot should stay lit and you gently turn knob to on. if pilot goes out you may have a bad thermocouple. be especially careful if its lp or propane as that gas does not disipate like natural gas and can virtually lay on the floor till ignited. also consider having the heat exchanger checked by a pro with a carbon monoxide detector. they do crack after a few years and can be deadly when they do. good luck
Nov 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
55 people viewed this question
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Michael Van Der...
Michael Van Der...
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
