Amana ALE643RBW Dry will not start. I checked the thermal fuse
and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
