Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
Pilot light will not stay lit om furnace - Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
No pilot feed or it is dirty and or cob webs may be disrupting flow. Clean every thing and relight.
Posted on Nov 04, 2013
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
Pilot light on Tempstar furnace wont stay lit. replaced thermo-couple and it still wont stay lit. what next???
Do you have a good pilot flame? Is it wrapping around the thermocouple good? You may need a new pilot orifice.
Mar 07, 2014 | Heating & Cooling
Pilot on my gas furnace won't stay lit
Try cleaning the thermocouple tip if you can see ashes or any buildup on it. If you know the wind isn't blowing it out (had mine blow out from high winds before) then I would change the thermocouple before anything else.
Dec 09, 2013 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
I can't get the pilot light on my furnace to stay lit.
take out the pilot assembly. there is a small burner and an orfice. the orfice does get clogged if it has not been operated for awhile. you can clean it out with a small sewing needle. if the pilot wont light or stay lit, replace the thermocouple.
Dec 06, 2009 | Heating & Cooling
Will it stay lit for a while? If so light the pilot light, Turn on the blower fan, and watch the pilot light. Look for any air that's blowing the pilot light around. if the pilot lite is moving around then you could have a bad heat exchanger. If so you should get a carbonmonixide detector and have your furnace inspected for this. One thing to check also is make sure the thermocouple is at least 1/4 inch into the flame.
Nov 12, 2007 | Heating & Cooling
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
