Question about Cycling
Raleigh sc30 crank bearing
3 Suggested Answers
  • 3 Answers
SOURCE: lower the seat on a Raleigh SC30 Bicycle
There should be bolt or quick release lever holding seat in position. Loosen the bolt or lever, adjust seat, retighten. If seat post is stuck, apply some WD-40 or similar lubricant, wait a while, and try again. you may have to twist seat to turn post and break loose if there is rust.
Posted on Mar 25, 2012
SOURCE: does anyone know how to lower the seat on a Raleigh SC30 Bicycle?
usually, the saddle is mounted onto a male shaft that fits into the rear female of the frame - this can be loosened by undoing a nut located under the saddle. it will loosen and you can then twist it up or down - it still remains quite tight. don't forget to re-tighten.if this is the obvious solution that you have attempted, then I apologise, but this is how all saddles are adjusted - I thought - here in UK at least
Crank bolt
You need to go to your LBS (local bike shop). They usually have replacements for less than a $1.
Nov 01, 2012 | Raleigh Grand Sport 2010 Bicycle
Raleigh tora bike pedal removal, i got the pedal off how do i remove the inner bar
You have to either buy a crank arm removal tool, or take it to a bike shop. There is no other way. I recommend using your local bike shop since they charge very little for this, and you can easily ruin the bike without some experience with the tool.
May 12, 2012 | Raleigh Cycling
Does anyone know how to lower the seat on a Raleigh SC30 Bicycle?
Mar 25, 2012 | Raleigh USA Bicycle Company SC30
Lower the seat on a Raleigh SC30 Bicycle
How do you take the cranks off a raleigh mojave 5.5
Most three piece cranks are pressed on the bottom bracket spindle, they all require a special removal tool that your LBS (local bike shop) should have. Park Tool makes a good one and they are about $15-20. Your LBS will probably remove it for less.
Mar 19, 2012 | Raleigh Mojave 5.5
I have some space between the rear axle and the bearing hub on my Raleigh M40. Can you tell me if you have both an axle and the the bearings hubs for each side?
We don't supply parts. Advice. Take the wheel to a bicycle shop for an assessment as the parts are not universal among the different hub makers.
Aug 20, 2011 | Stickers Raleigh Mountain Road Tri Race...
Raleigh sc30 bicycle has a front shock absorber. Is it adjustable or can I make it just be solid?
I can't find any doxumentation anywhere for that model.
http://www.raleighusa.com/downloads/
I'm guessing the technology is elastomer so the only option for adjustment would be to replace the elastomer, if they even make different ones.
May 04, 2011 | Cycling
I have a SC30 model weed whacker and need "bulb as...
I've found the most inexpensive location for this as eBay. Typical costs are about $7.00 delivered. This is a very standard bulb assembly for the Ryobi: PART#1885121
It would generally be available at your local lawnmower or small engine repair shop as well.
May 21, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Does anyone know if all of the components from a 2000 year model Raleigh Serengeti Mountain bike will fit on a 2006 Trek 4500 frame? I am looking at upgrading to a lighter frame, but like the components on...
They ought to. Bicycle components are quite universal. You may run into a part or two which won't fit (front derailleurs have to fit frame design [especially on full-suspension bikes] as well as tube diameter), and you must bear in mind that the geometry of the new frame will most assuredly be different, so your handlebars and stem may no longer be familiar or comfortable to you. Good luck!
Aug 26, 2009 | Cycling
Cycling Logo
23 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
