Question about Lexmark E330 Laser Printer
My Lexmark E330 printer keeps printing coding on paper instead of the documents I want it to print, how do I remedy this?
  • 37 Answers
Are you, by any chance, trying to print a PDF file? If so, you need to use the print feature in the PDF reader and not the print capabilities of your operating system.
Posted on Oct 21, 2013
Testimonial: "Thanx, but I have this problem no matter what type of document I try to print"
Ajkill
  • 2035 Answers
SOURCE: LEXMARK PRINTER DOES NOT WORK JAMS PAPER
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 14, 2008
  • 684 Answers
SOURCE: Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Posted on Jan 19, 2009
Roop1980
  • 228 Answers
SOURCE: Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
Posted on May 08, 2009
techbuster
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
Printer does not recognize the paer loaded
You'll have to go into your settings on your PC to change the parameters for your printer, Usually under settings or Properties Tab..Change the Paper to what size you want to have it print on I.E. 8.5 X 11.5, legal, envelope Ect.
Sep 22, 2013 | Lexmark E330 Laser Printer
My lexmark E340 printer displays the message: "remove cartridge paper jam" continuously and not print more pages
There is probably a sensor that is being blocked by paper that you might not be able to see easily. Remove cartridge and check the inside of the printer with a flashlight. Please turn off printer before doing this.
Sep 06, 2013 | Lexmark E230, E232, E234, E238, E240,...
The printer isnt working keeps telling me printing complete
Follow the steps below to fix the problem:
1. Align the print cartridges (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Align to fix blurry edges > click Print) 2. Clean the print cartridge nozzles (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Clean to fix horizontal streaks.) 3. Remove and reinsert the print cartridges. 4. Wipe the print nozzles and contacts using a slightly moistened soft cloth to clean it from dirt or clogs.
Try to print a document again to verify that the problem is fixed.
Oct 22, 2011 | Lexmark Z1420 Printer
When i send a document to print on my canon pixma mp270, the paper only descends partially into the printer. how can i remedy the situation?
The problem is in the way the papers were loaded into the printer.
Watch this video:
http://www.youtube.com/watch?v=m65wxbtxuMw
Although it's for Lexmark printers , the principal is the same.
Let me know how did you manage.
Regards,
Sharon
Feb 02, 2010 | Office Equipment & Supplies
Erre lights on Lexmark E330 what is second one from bottom?
error light on out of paper also toner light is flashing but its a new toner kit and there is no paper jam
Sep 30, 2009 | Lexmark E330 Laser Printer
Ink marks on paper
seems that the Print roller needs a cleaning. get it cleaned as there might be some extra ink on the roller.
Hope this Help.
Cheers!!!
Jul 16, 2009 | Lexmark E330 Laser Printer
I need color documents from my x2500 lexmark printer
Okay if your using windows OS go to control panel , then printer and fax icon open it you will see Lexmark printer series listed right click on it and go to printing preference tab ,uncheck print all documents in black and white click okay and then try to print....
Good luck...
Feb 25, 2009 | Lexmark X2500 All-In-One Printer
34 short paper
The printer does not auto detect your paper size and so when your Legal size document was printed on Letter size paper, you get a 34 Short Paper message.
Feb 07, 2009 | Lexmark C510 Laser Printer
Lexmark e330 doubts
Please use this link it may be helpful:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Feb 26, 2008 | Lexmark E330 Laser Printer
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Lexmark E330 Laser Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
