I get the following error when I start Window (7); RunDLL There was a problem starting C:\Windows\System32\SDTablet.dll The specified module cannot be found. How can I fix it? I've run Glary Utilities and Glary Registry repair to no avail. Thanks
  • Mark McKown Oct 22, 2013
    Problem Solved! After sifting through 8 pages of phony "PC Cure-All" links on Google, I found that the .dll refers to a registry entry associated with "SmartDraw" (learned this from Binarydb). As far as I know, this program was never installed on the computer. I set a restore point, went to "Regedit", located the .dll and yanked it. Rebooted, no error message, ran Glary Registry Scan and all is well.
  • 4 Answers
1234567089
Posted on Oct 22, 2013
4 Suggested Answers
  • 5 Answers
SOURCE: RUN DLL ERROR
IF YOU HAVE ANOTHER COMPUTER IT WOULD BE EASIER, IF NOT YOU WILL HAVE TO PRINT OUT THE INSTALLMENT DIRECTIONS FOR ELIMINATION OF THE ERROR PROMPT. IT'S TIME CONSUMING SO IF YOU ARE IN A RUSH, FORGET IT.(UNLESS YOU ARE A COMPUTER GEEK) :) YOU WON'T BE ABLE TO ACCESS WINDOWS FROM THE COMPUTER WITH THE ERROR, GO TO ANOTHER COMPUTER, PULL UP WINDOWS SUPPORT, THERE'S A SECTION THERE FOR ERRORS, IF YOU DON'T SEE IT RIGHT OFF, JUST DO SEARCH ON THE LEFT HAND SIDE BAR, "DLL" OR "ERRORS" ANY OF THESE WILL PULL UP YOUR FIX. PRINT 'EM, APPLY, AND YOU'RE UP N RUNNING!!!
Posted on Oct 24, 2008
taran_2005
  • 10515 Answers
SOURCE: When I start up Windows XP I get three error boxes
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 08, 2009
taran_2005
  • 10515 Answers
SOURCE: When starting computor I get
This is not a major problem, though this could cause your windows to be corrupt.This error means a presence of corrupted file ( Kaspersky Internet ).
Most probably you need to repair the windows using windows cd or restore the computer. However, you could try to fix this problem by following the below method :-
Download :-
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
After run script, attach a Combofix log, please review and follow these instructions carefully.
Before Saving it to Desktop, please rename it to something like 123.exe to stop malware from disabling it.
Now, please make sure no other programs are running, close all other windows and pause Kaspersky (right click the K icon and click pause protection > Choose the
option "resume manually" if still active) until after the scanning and removal process has taken place.
Please double click on the file you downloaded. Follow the onscreen prompts to start the scan.
Once the scanning process has started please DO NOT click on the Combofix window or attempt to use your computer as this can cause the scanning process to stall.
It may take a while to complete scanning and this is normal.
You will be disconnected from the internet and your desktop icons/toolbars will disappear during scanning, do not worry, this is normal and it will be restored after
scanning has completed.
Combofix will create a logfile and display it after your computer has rebooted. Usually located in c:\combofix.txt, please attach it to your next post. Also, please don't
forget to resume the Kaspersky that you paused.
Let me know,if needed further assistance.
Hope i helped you.
Posted on Dec 11, 2010
So how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
Fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
It gives messsage for dll missing.
From what i have read, this is malware, a trojan.
You need to get rid of it.
Run a program like Malwarebytes in safe mode (F8 on boot, choose safe mode with networking) also run with system restore OFF, lots of malware and viruses hide there.
Follow this guide....
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 27, 2010 | Microsoft Windows Vista Ultimate with SP1...
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Hope i helped you.
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
Error message rundll on startup
Looks to be a left over file. Probably not needed - this happens when you delete a program, but other files remain. Go to start button - click on search - click on all files and folders type lumejeji.dll in the top box - hit the search button
it will find the file - you can either drag it to the recycle bin or right click on the file and go down to delete and left click that.
Should fix your problem
HOWEVER
I just looked this .dll file up - Here is what I found - you may want to delete the file and run a virus scan as well
hope this helps
UMEJEJI.DLLFraudulent Security Program Your PC is infected. The file called LUMEJEJI.DLL is considered unsafe and there may be other infections on your PC.
You should urgently check your PC and remove any malicious software including LUMEJEJI.DLL as soon as possible.
Dec 30, 2008 | Dell Dimension 4600 PC Desktop
RUNDLL error loading c:\WINNT\system32\xlipladg.dll
I don't have this on my W2k system. If you can boot into safe mode and do a search for it, you probably could delete it. As there is no system restore in W2K, the best thing to do is make a backup of your documents and settings folders or at least your documents.
This also could be associated with something downloaded or installed recently.
A search on the internet returned no result so its not in any current databases.
So, boot into safe mode, search for it, rename it xlipladg.old and reboot.
Regards,
Worldvet
Ask any questions using the comment box below
Dec 11, 2008 | Microsoft Windows 2000 Professional for PC
RUN DLL ERROR
Oct 24, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
