Question about Home
My clock has blanks in between the #s sometimes and blanks sometimes other places, so I put new batteries in both pieces and it still reacts the same. how can I fix it?I have a s1oscan clock
INSTRUCTIONS SHOW PLACES FOR 4 BATTERIES AND THE 1 WHERE THEY SHOW THE CLOCK BATTERY , OURS DOESN'T HAVE A PLACE FOR A CLOCK BATTERY?
Sometimes manufacturer make changes in model and keep old manual
Contact SEIKO USA (presuming you are from USA) And ask them for updated manual for your model. SPECIFY THEM YOUR MODEL!!!
http://seikousa.com/contact-us
Sep 30, 2015 | Seiko Musical Wall Clock
Blank screen
Sometimes all it needs are new batteries.
Jan 02, 2012 | SkyScan 86742 Digital Atomic Wall Clock
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Pf on indicating area reset clock, oven light
Make sure the range is not plugged into a GFCI outlet. This could be a sign of a bad ground connection some place or a bad solder connection on the control board. Not easy to locate sometimes and may require a new control board.
Eric
Dec 18, 2009 | Whirlpool Kitchen Ranges
Its really slow. doesnt react easily sometimes
From the TI Knowledge Base and FAQ Hope it helps.
If a piece foreign material such as a pencil lead is lodged in the I/O port of the calculator, it may create a short causing the calculator to respond slowly to key press entries.
If the piece of conductive material can be removed, it may restore the calculator to normal operating condition.
If the material cannot be removed, contact TI-Cares Customer Support to proceed with an out of warranty product replacement.
If conductive material is not lodged in the I/O port and the calculator responds slowly to key press entries, contact TI-Cares Customer Support for further troubleshooting and resolution.
Nov 01, 2009 | Texas Instruments TI-84 Plus Calculator
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
Display is blank, radio/clock won't turn on.
call the costumer service for that they are always really nice and helpful!
Feb 10, 2009 | RCA RP5430 Clock Radio
Blank screen, very soft speaker
u first tak out ur battery for sometime and then replace it. there might be some problem in the battery. else u would have mistakenly put it down.. else u must contact a service center..
Oct 15, 2008 | Samsung SGH-E370 Cellular Phone
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
27 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
