Question about Lands Phones
Uniden Dect 6 Manual
The phone hangs up on the caller after 1 or 2 rings. They do want to speak with me and visa versa
SOURCE: Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Posted on Apr 24, 2008
SOURCE: I have a uniden dect
Hi, I have a dect 2035 and began having the same problem. I don't know how the feedback came about but it was suddenly there today when I tried using the phone. After mucking around with one of the handsets I hit the speakerphone button and turned the volume all the way down, it only goes down to a preset minimum, I then turned speakerphone off again and turned the volume for regular handset mode all the way down too. The phone works beautifully again!
Posted on Feb 13, 2009
  • 95 Answers
SOURCE: uniden cordless phone 900 MHz
A phone uses a voltage drop to determine when it is answered or hung up. What is happening in your case is the phone or base unit, or worse yet the house wiring has a short to ground somewhere. This also cause the static you hear. You can get a regular phone and plug it into the same cord and see if it works normal. If so it is not the house wiring but the phone or base unit. If so you can only hope to find the short yourself which is very time consuming and difficult on modern digital units. Sorry to say it's cheaper to get a new unit than pay for repair. The only other thing that cause those symptoms is the batteries are going dead. I assumed you checked this first. If not you can try changing the battery pack on the phone.
Posted on Mar 28, 2009
cnavarro
  • 2460 Answers
SOURCE: one ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
Posted on Aug 21, 2009
  • 569 Answers
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
Posted on Dec 16, 2009
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I remove the silent mode from my uniden cordless phone handset
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Feb 18, 2013 | Uniden DECT 6.0 Cordless Phone with...
How do you change the amount of rings on the uniden dect1363 6.0 GHz
The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
Phone only rings once then goes to greeting
This phone has one mode to configurate the "number of the rings" you need to programer this "time" Enter to this option always search as inside "MENU" follow your user manual also.
Jun 27, 2012 | Uniden DECT1560 DECT 6.0 Expandable...
How do I make the phone ring for longer before it goes to answering machine? I have a Uniden Dect 6.0 digital with answering machine but no caller ID.
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jun 29, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
15 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
