Question about HP Media Center m7260n (EG642AA) PC Desktop
Can not power on compurter - HP Media Center m7260n (EG642AA) PC Desktop
  • 37 Answers
Anytime you have problems like this, you need to make sure to check the basics first. Are the wall outlet and power cord both good? Plug another electrical device into the outlet to make sure it is working, and try connecting the computer with another cord.
Now that we know that there is power to the computer, look for any lights on the computer when you press the start button. Also look for any fan motion. A common problem with a faulty motherboard is that as soon as you press the start button, the power supply fan with try to spin, but will immediately lose power. Do you smell an "burning" type odors coming from the power supply? If so, you probably have a bad power supply.
At this point, you have to decide if you want to repair or replace you system. If you are truly running a pc with XP or Vista, you may want to consider upgrading to a new system. Your hard drives in your old system are probably okay, and if you purchase a new system, the drive may not be compatible with the new hardware. Older systems typically used IDE interface for hard drives whereas current systems mostly use SATA. The connectors, both power and data, are not compatible. You can purchase an external adapter which will allow you to connect your older hard drive to the newer system via USB, but you will have to re-install all of your older programs on the new machine, and hopefully, they will run on the new operating system. There should be no problems migrating your data files, music, photos, documents, etc. to the new machine.
Posted on Oct 21, 2013
I can not power on the compurter
A computer not powering on could be a large amount of things.
Try these things first.
  1. Power Drain the device. Remove all power sources from the device, thens hold the power button down for 30 seconds.
  2. Re-seat the RAM modules.
Attempt powering on the computer, with a DIFFERENT PSU (power supply unit)
Post back with results.
Oct 21, 2013 | HP Media Center m7260n (EG642AA) PC...
probably time to get a new power supply
Done head gasket mate put manifolds on now fuel pump diont work no power to pump power at relay starts with blast of fuel no power from compurter to pump
computer doesnt control pump relay on such a old vehicle ,you have a fuse out or old dirty connections on the base of the relay so if all else fails then run a new feed wire to relay depending on which power point on relay has no power ,if its the feed from ignition to operate relay make a new feed from ignition switch and if no power to pump side of relay then run a new feed to this via a fuse .simple to sort out on such an old vehicle
Mar 12, 2011 | 1990 Daihatsu Rocky
Dell Dimension 4600C Compurter running fast and
Try to check the fan and the inside of the desktop for any dirty things in there. Especially check the fan to see if something is stuck!
Mar 04, 2011 | Dell Dimension 4600 PC Desktop
The office compurter is loaded with ms office 2003.the data prepared in ms office 2007 is not opening in my office compurter ..how to solve4 the problem
Download and install the below patch in your office computer:-
http://www.microsoft.com/downloads/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
May 20, 2010 | Computers & Internet
Laptop monitor black out
You may have failed backlight inverter or bad lamp, or not getting the power to the inverter due to loose cable.
Please check out this place to get some ideas:
www.insidemylaptop.com
http://s807.photobucket.com/home/budm/allalbums
Apr 25, 2010 | Toshiba 17 LCD Monitor
We have followed the instruction to set up and download games from the Sony site but we cannot find the cart/checkout icon. There is £80 in the wallett. Download latest version of Media go, created an...
are you logging in with your psp or on your compurter? on your compurter you will be able to browse the content but won't be able to buy anything. for piracy reason. if you want a game for your psp you have to log onto psn with your psp. psp and ps3 are the only 2 system that you can buy games with on psn
Mar 23, 2010 | Video Game Consoles & Games
Usb ports no communication with compurter but supplies power. what is wrong ?
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Does the 'USB' branch of the tree show the USB ports?
Is there an 'Unknown Devices' branch of the tree?
Either way, the software "device-drivers" for the USB ports are not installed, or not installed correctly, and so you'll get the symptoms that you've observed -- power without device-recognition.
Access http://support.dell.com and click "Detect My Computer", and download and install the device-drivers for the USB ports.
Dec 30, 2009 | Dell Dimension 4600C PC Desktop
Video problem
change the controller of your hard disk and your cd device to new one.... might be the problem at connector or controller...
Jun 17, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
My pc is not working , power button wire is open they joint me but my mother board book is not avilable pls tell me the my qustion
Dear user,
Pl read around the front panel pin side in small letters what pin where fitted in pin so try this to start your compurter.
*********** board is working ok or not ?
Jun 02, 2009 | MSI 845 PRO Motherboard
HP Media Center m7260n (EG642AA) PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
