Question about Sony DAV-DZ810 Theater System
CD tray opens even without opening it.it cant play because the tray cant stay inside.
  • 34 Answers
Slack pulley rubber may be the cause.This can only be fixed by a qualified technician.
Posted on Oct 21, 2013
3 Suggested Answers
SOURCE: Cd is not read .. evrytime teh player is opening .. wile redaing saying NO DISC
ur cd's wheel rubber must be loose for this reason u face the problem, plz change ur cd player's wheel rubber and check
Posted on May 26, 2009
jerry_kramer
  • 3904 Answers
SOURCE: CD/DVD tray will not open.....happy
These get stuck on everything with or without a disk. My advice is to take the cover off and see what it is hanging up on. It is almost never a motor. I would bet something is just off a bit that is causing the stick. There should be 4 to 6 screws to remove the cover and that will expose the drive itself. There will be a gear in there too that is usually white and plastic. That could be off the cog and just needs a tap to get it back on track.
Posted on Jun 16, 2011
My Sony home theater model hbd-dz810 CD tray cant stay in and play,it opens itself immediately.i have cleaned the gears but still not working.please help.
A slack pulley rubber may be the cause.This will cause the tray not to load fully and will not allow the open/close switch to make contact. However,this can only be fixed by a qualified technician.
Oct 21, 2013 | Audio Players & Recorders
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
My CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Jul 21, 2006 | Yamaha CDC-755 5-Disc CD Changer
Sony DAV-DZ810 Theater System Logo
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
