Question about Panasonic Lumix DMC-FZ7 Digital Camera
Green pictures panasonic fz7
Hi i've had my fz7 for a few months now and have taken about 1500 shots but the past 100 or so have had a bright green light showing in the well exposed area's of the photos even in simple mode. i have set every thing to auto but this does not resolve it.
  • BlueTone May 05, 2008
    In shutter and aperture modes, my Panasonic FZ7 displays with a blue tone, and when downloaded the photos are also blue monotone. In simple and scenic modes, it's full-color.
    Problem Solver:
  • 15 Answers
Check the WHITE BALANCE settings and the COLOR EFFECTS settings (marked as W. BALANCE and COL. EFFECTS when MENU is pressed).
When you got to the MENU setting, press up or down arrow until you reached either selection, press the left arrow, and you'll see several options under the selected function. In WHITE BALANCE, there's an option whether you'll be shooting under sunny or cloudy skies, tungsten or flourescent lighting, and an option to select Auto or Manually set White Balance. This affects the over all color tone as it compensates the color correction depending on your shooting conditions. Fluorescent lighting for example exhibits blue spectrum, thus setting White Balance to FLUORESCENT will add warm or yellow tones to the photo. Tungsten lighting and sunny conditions exhibits yellow lighting, and setting to the White Balance on this mode will add cool or bluish tone to the picture.
Same with COLOR EFFECTS: settings include WARM, COOL, SEPIA or BLACK AND WHITE (gray scale).
Chances are, you have accidentally set the WHITE BALANCE or COLOR EFFECTS to any of these. To see if this is the problem, try shooting under SIMPLE MODE (Marked with a HEART icon at the rotary dial on top right of the DMC-FZ7). If the problem goes away, then it is with the WHITE BALANCE and the COLOR EFFECTS settings. Try setting the COLOR EFFECTS to "OFF", and the WHITE BALANCE to "AUTO".
If all else fails, then you got a problem with the image sensor of your Panasonic DMC-FZ7 Digicam
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Site Creator, TEENMODELS2007
http://teenmodels2007.wetpaint.com/
Posted on Sep 11, 2008
  • 4 Answers
Can you post a link to a sample photograph? Also, is the green light always at a localised/specific area or spread across various photographs? Regards Virdi
Posted on Oct 01, 2007
SOURCE:
My Panasonic Lumix DMC-FZ7 will not read memory cards. It displays "MEMORY CARD ERROR, PLEASE CHECK THE CARD"
It wants you to format the card in the camera. This will erase the card so download any pictures on it first using a card reader if necessart.
Oct 14, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Delete & double pictures
you probably have the burst on. I have done this lots of times. before you get ready to take your shot, push the delete button until the multi-burst icon goes away. this will be represented by what looks like stacked boxes followed by either an H, an L, or a sideways 8 (or infinity symbol). that should solve your taking 2 pictures at once thing.
Aug 17, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Water spot inside the lens on my Lumix camera
DON'T EVEN TRY TO TAKE THE LENS OFF!!!
To take the lens off, the camera has to be dismantled, and unless you are an experienced technician, there is a 95% chance that the camera will have more problems than what it started with.
Have you taken any pictures with the water spot inside the lens? If it is visible in pictures, then you have several options:
1. Ignore it.
2. Leave it there and use an image editor to clone out the spot in the picture. (Recommended).
3. Take the camera to a repair shop, or mail it to Panasonic's service center. This is the expensive option, to remove the water spot, the price most likely will be well over $100.
4. Buy another camera. The FZ7 is rated to about 50,000 shots, so if you are approaching this number they it may well be worth it to just get another camera.
Unless the spot is seriously affecting your pictures, then leave it there. By having the camera opened there is a high chance that other problems will be introduced, such as: fingerprints,dust or hairs inside the lens or misaligned lens elements.
My FZ7's lens is full of dust, yet this is not usually visible in pictures, when it is, I can usually remove it on the computer.
I would recommend taking the camera to a service center as a last resort.
Jul 10, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Problem taking pictures after number 48 is shot.
Are you using a panasonic SD card? The camera may not function properly when a cheap SD card is used.
I also have a FZ7 and it works better with a memory card of the same brand.
Also, if the card or the camera are old, they may be worn out.
Jun 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Screen Brightness
Your ballast may not be up to 100% of its rated capabilities, thats often the cause when the brightness level gets to unwatchable levels. You may need to troubleshoot the ballast voltages a defective ballast can usually cause a lamp to loose about 60 % of its brightness levels. The other possibility could be the DLP mirrors need polishing but that is something better left to a repair shop as the DLP mirrors are sensitive
May 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Images with white horizontal lines
Send it back to sony, It has recall for this problem, Ck web site.( Sensor chip is bad )
Jun 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
231 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
