Question about Sharp Aquos 32 inch LC-32LE340M LED Multisystem TV FOR 110-220 VOLTS
Tv is dead means power supply board is ok but whn we connect the main unit the voltage drop from 12 voltage to 7 or 8 what should i check
    Top Expert:
  • Sharp Master
  • 74,383 Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 22, 2013
  • 308 Answers
SOURCE: If my Sharp Aquos 37in LC-40C37U tv needs to be
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Posted on Apr 30, 2010
Testimonial: "Thank you. I will get another board."
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
Slinteriors
  • 8617 Answers
SOURCE: ok, but my power supply is good ,but still very dead
need the actual model number from the set. Also does the power light come on or blink? If it blinks let me know how many times its blinking and I will assist with the issue.
Posted on Feb 19, 2012
gopakumarg43
  • 74383 Answers
SOURCE: Problem with Sharp LC40le700un
Contact the autthorised service center for Sharp at your town.
Posted on May 08, 2012
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
26LG30R MAINBOARD IS NOT WORKING
Check the power supply regulator board, with no load condition, and make confirm that the 12V supply line is OK, by connecting a 12V filament type bulb in place of load. if it is found OK, and no voltage drop occurs, be sure that the main board of this TV is faulty. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 12, 2014 | Televison & Video
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
My TV Wouldn't On
if no any power light indicator at the front of your tv that was mean the unit is dead set or no voltage that is circulating in the main board and other boards.if you can remove the rear cover of your tv, the first place to check will be the power supply board if the primary fuse was blown. if the fuse is blown with darkened color that was mean has shorted component either in the main board or in the power supply unit. if the fuse blown with clear color just replace with the same rating.
Aug 02, 2012 | Televison & Video
Unit hit by lightning. Replaced main fuse. Power supply works. Replaced main control unit. Both green and amber lights blink constantly
How many times does the standby light blink between each pause? Its a self-test diagnostic that will pn-point us to the source of the problem so please let me know.
Aug 18, 2011 | Sony KDL52NX800 52 in. TV
TV had no picture first and then no sound. I have unpugged TV and still nothing happens. There is a blinking red light on that can be seen from rear of TV ( 1 blink on and off). Thanks for your help.
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
A Power supply is like this..(It is not actually look like yours but it was just for your Idea)
Please let me rate and testify by you when you find my solution helps you...
I hope this solution helps you to fix your problem.Thank you and good luck.
Jul 12, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have an lg 32lx2r tv the stand by light comes on but the tv dont. some thime if i switch it off at the mains then back on then the tv comes on but not all the time. what can i do & can you help...
Good day!
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
Apr 20, 2011 | Televison & Video
The tv powers up for about 30 seconds and then the power light starts blinking fast and the tv shuts off i think it is the main board but any suggestions would help
Good day.
This the procedure that you have to do.
  1. Remove the cover of your TV.
  2. Power on the TV to apply voltage data.
  3. Check the power supply output.5vdc for main board supply,12v for the sounds and 24vdc for back-light inverter.
  4. If any of the 3 supplies are missing or got a voltage drop,there's a problem with your power supply.Check some leak/bulging top capacitor.
  5. If the 3 supplies are OK,the problem is on the main board of your TV.Replace it.
I hope this solution will be helpful.Thank you for using FixYa.Good luck.
Apr 17, 2011 | Sylvania LC420SS8 LCD TV
What causes a 32c110u screen to blank off after about 2 seconds of powering on.
Good day.
This are the procedures to find out the causes:
  1. Open the back cover by removing all screws.
  2. Power ON the TV to perform voltage data.
  3. Check the output voltage of power supply if there's a 5vdc for main board,12vdc for sounds and 24vdc for the inverter board.If any of the 3 is missing or having voltage drop.The problem is on the power supply,check some open resistor or leak/bulging on top capacitor.
  4. If your power supply is OK and the 3 supplies that mention above are complete and no voltage drop and your TV is having sounds but no picture.Check output voltage of the inverter board it should have 500vdc so be careful.
  5. If the 1 to 4 steps are properly work the problem is the main board.
I hope this solution will be helpful.Thank you for using Fixya for assistance and good luck.
Apr 17, 2011 | Toshiba Televison & Video
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Hisense TL2020 LCD TV
You should check the 12 volts capacitors on your power supply for dry or leaky, bulging conditions.
Replacing those capacitors will restore the functionality of your TV.
May 15, 2008 | Televison & Video
Sharp Aquos 32 inch LC-32LE340M LED Multisystem TV FOR 110-220 VOLTS Logo
77 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
