Question about White Sewing 955 Mechanical Sewing Machine
When i press on the foot, it makes noise but doesn't do anything. Also, the knob on the side of the machine that moves the needle up and down, is really tight and doesn't move easily.
    Champion:
  • 208 Answers
Quite likely you have a minute piece of thread stuck in the raceway
Posted on Oct 21, 2013
3 Suggested Answers
SOURCE: Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Posted on Mar 19, 2012
SOURCE: Needle won't move
Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew. This should help, it helped me!
Posted on Jul 19, 2012
The foot pedal is not moving the machine but still makes a noise
A: You said, "The your foot pedal is not moving the machine, but still makes a noise". . . . I'd suggest checking if the sewing machine has a disengaged or broken drive belt, gear or linkage; if not the problem, may just be that the Hand-Wheel clutch mechanism (on the left center of the Hand Wheel) is in the Bobbin-Winding position. If so, it allows the machine to cycle, operating the Bobbin-Winder without the needle moving up or down. Older Brother machines, like many other brands, used a large flat shiny Screw Knob in the center of the Hand Wheel to engage or disengage the Bobbin-Winding feature, newer models use a plastic teeter-totter switch located in the same place, to do the same thing. Keep tinkering, you'll will resolve it.
Sincerely,
-- Amender (2016 FEB 23)
Feb 03, 2016 | Brother Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
Singer Prelude 8280 Sewing Machine stuck
Is the knob on the side, where you loosen the needle to rewind the bobbin, tightened? Also, there may be some threads in the bobbin case messing things up. Unplug the machine if you are checking the bobbin case.
Apr 18, 2013 | Singer 8280 Mechanical Sewing Machine
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
White Sewing 955 Mechanical Sewing Machine Logo
57 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
