Question about Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta
After loading disc from camera into the photo frame, the phrase "loading" appears and stays on the screen
    New Friend:
    Problem Solver:
  • 6 Answers
What do you mean, loading disk... you mean card?
Posted on Oct 25, 2013
Sylvania photo frame screen won't come on
No brainer back light on photo frame is no good.
Been there. done that trashed it. I lost reciept.
Dec 20, 2013 | Cameras
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
The photos on the frame aapear
You may have to change the screen resolution on the frame if it can be changed. Some frames do not allow a change in this way. If you cannot change the resolution then try changing the size and resolution of the photo's on your camera. You may have to change things several times until you find the best fit. Refer to the manual for the frame on how to change the frames display size and resolution..
Apr 02, 2010 | Microsoft Windows XP Professional
Frozen Screen on Digital Photo Frame
I have the same problem!!!
Did your frame already work?
Feb 15, 2010 | Philips 6.5-Inch Digital Photo Frame...
HTC touch HD camera problem
If you done, all what is possible. Now try do next:
Push camera button and wait until camera frame will loaded. Dont release camera button. Now push hard reset key. And during restart keep camera button. Whan system will loaded, you can try use camera.
Mar 06, 2009 | HTC Touch HD Smartphone
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Transferring photos from digital to photo frame- How to? Please
If you need to transfer to your computer just connect the USB cable from the camera to the computer, switch the camera on, turn the dial to View and Voila! A connect icon appears on the camera screen. Follow instructions on screen to download photos; develop if necessary. Presumably you will then be able to download the jpegs to your photo frame from your computer.
May 27, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta Logo
29 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
