Question about Kenmore 35 Pint Dehumidifier with Electronic Controls
Shuts off and water leaks from the bottom of the dehumidifier
    Top Expert:
  • Kenmore Master
  • 35,572 Answers
The condensate tank may be overflowing
Posted on Oct 21, 2013
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
My Maytag dehumidifier runs but does not collect water in the tray. Instead, it appears to leak from the bottom and ice formed near one of the side portions. Please let me know what you think is the...
This one has a leak in the refrigerant system... it will need to be found, fixed, and recharged...which will cost more then a new one...in most cases.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 13, 2011 | Maytag Dehumidifiers
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Goldstar dehumidifier won't run
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 14, 2010 | Goldstar DH504EL Dehumidifier
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
Leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Jul 17, 2007 | Maytag M7DH45B2A Dehumidifier
Kenmore 35 Pint Dehumidifier with Electronic Controls Logo
69 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
