Question about HD SUPPLY MAGIC-PAK WALL UNIT - 51HWC184A-1 R-410A - Freight
Fan motor keeps running - HD SUPPLY MAGIC-PAK WALL UNIT - 51HWC184A-1 R-410A - Freight
Why does fan motor keep running after engine is shut off
This is normal and there should even be a warning label near the fan shroud. It is cooling the radiator and as long as it eventually does go off there is nothing to worry about.
Jul 21, 2014 | 1999 Dodge Caravan
Fan outside isn't running and when turned on the unit outside is running very loud.
The fan outside keeps your compressor cool, the compressor, if left running without the fan running to cool it down can get damaged, the fan normally gets its power from a switch box located outside or near
it. or the motor on the fan could have just gone bad. the fan motor is not as expensive as the compressor to replace. its easy to replace. sometimes what goes out 1st on these motors is the capacitor,the capacitor stores enough voltage to give the motor that extra push to turn. many times its just the capacitor that goes out. when you purchase a motor make sure you also get the matching capacitor.if you can turn the fan and it starts running, its the capacitor, if it starts running and has any kind of bearing noise then you will have to replace the motor. good luck!
Aug 08, 2011 | Heating & Cooling
After Eng is turn off A/C & heater fan keeps runing dranig
The fan runs off a module incorporated inside the blower fan motor. The motor assembly will need to be replaced for its all electronic inside
Jun 22, 2010 | 1996 Buick Park Avenue
Fan does not run. Compressor is running. I can spin the fan, just doesn't run.
If the fan motor is getting the proper voltage and the capacitor is good the motors bad.
Either open windings or overload is open.
Mar 15, 2010 | Dometic Rooftop RV Air Conditioner
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
The fan motors keeps running after car is shut off. Also sometimes fans start when car is started cold.
If the fans didn't run any further the engine continues to warm and possible seizure will occur. This is also the reason you will probably go through batteries in the long run. Hopefully this helps the issue you are having.
May 25, 2009 | 2003 Mazda MPV
The fan keeps running by the motor
the fan must only run when the motor are running
May 15, 2009 | Sub-Zero Bottom Freezer Refrigerator
Fan motor for rear hvac doesnt shut off
you have a fault somewhere my best bet is to take it in for a check up
Feb 15, 2009 | 2003 Chevrolet Tahoe
Fan motor keeps running on Audi A4 2004
fan motor has a thermal switch which turns on the fan as soon as the engine heats up. what happened there is that the switch is stuck on the closed position which keeps the fan on all the time. you should go to a garrage and have the part changed.
Jul 20, 2008 | 2004 Audi A4
HD SUPPLY MAGIC-PAK WALL UNIT - 51HWC184A-1 R-410A - Freight Logo
18 people viewed this question
Top HD SUPPLY Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a HD SUPPLY Heating and Cooling Expert? Answer questions, earn points and help others
